A true Locker VS the Detroit Truetrac, Which is better?
#16 | |
hey man i know you are talking about lockers.. but ever think of having an 8.8 done for you? im not talking something crazy expensive. If you are contemplating a super 35 kit for the money you can do better with the 8.8, have it welded and locked probably for about that S35 price or close to it.
I got m 8.8 for 250 with 4 10s anf factory posi. i happen to like the posi but for your needs its safe to say you want a locker. I got mine from dons auto mall in binghamton NY they deliver to local garages. it was 250 welded it up. regeared it my self with a mechanic friend. all in all it was in my jeep for 650$ i have a friend who got his 8.8 from the junk yard ( we pulled it ourselves) for 75 bucks. add that up that much cheaper and much bettter solution then a d35. it is 5x4.5 too so your rims will work fine. it is also disc brake ( 96-01/02 ish explorer (dont quote me) ) 31 splines. it is my understanding that an 8.8 (31 spl not 27) will handle 38s and V8 power. and it is said that the 27 slpine version is still stronger then a stock d44. all in all i love my 8.8. i love spinning tires. with 35s i have never had a problem. im coming up on 2 years. with the factory ford trac lock i have left posi marks in the pavement and never not gone where some one in my group has. good luck
#17 |
I was having the same ideas for locking up my axles. I just got an 04' rubi axle for my rear to replace my 35c traclok. Up front, I'm still up in the air. I'd like a lunchbox up front, but I deal with a ton of snow driving. I never really do rocks, but I likes da mud. I'd love to go selectable up front, but it's too costly. Looks like I might do TT.
Hold onto something... Quick!!! |
#18 |
Running Secretly Amok!
uh oh here it comes?
#19 |
#20 | |
I would strongly recommend *against* upgrading to 35" tires at this time unless you're willing to put a new rear axle onto your heep. I would also recommend, if you *do* want to stick with the D-35 rear, that you leave the rear open and put a lunchbox locker up front. Otherwise your D-35 is just going to break axle shafts, even if you upgrade it to Super-35 axle shafts. And because the D-35 is a C-clip axle, breaking an axle shaft means the whole bloody wheel comes off and you're pretty SOL unless you're carrying a spare axle shaft with you and the tools to fix it on the trail . |
#21 |
Do it right or not at all
![]() Join Date: Jan 2003
The Super 35 kit is well known to hold up to 35" tires with a locker. There are more than a few that even run the infamous Hammers trails in Johnson Valley on 35" tires with Superior Axle's 30 spline Super 35 kit. A locker is much harder on axles than the Truetrac is... which by the way is not even available with a Super 35 kit.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#22 |
#23 |
Why would a detroit truetrac not hold up to 35 inch tires on a jeep?and why would you say that.
#24 |
I was trying to figure that out also. I had a tru-trac and 35's on my dana 35 for a little over a year and no problems. I've had a tru-trac and 35's on my dana 30 for like 4 years and its still holding up. I just broke a front outer axle shaft but the tru-trac still good.
#25 | |
You can certainly run a TrueTrac with 35 inch tires. You can run a Dana 35 with 35 inch tires too. You *will* eventually break something, though. Which probably isn't a big problem if you're on a group run and your Heep is a trailer queen, you can get a tow out then tow it home. If you're in the middle of nowhere you have a bigger problem. |
#26 |
Drink Oregon Craft Beer!
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
Is it because the TrueTrac uses 27 splined shafts and doesn't have the option to go to a beefier 30 splined shaft?
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather. [Edit] "Now jeepin in Oregon" [/Edit] |
#27 | |
#28 |
In a Dana 44, a 30 spline Truetrac could very likely handle even 37" tires.
#29 | |
I've got 3.73's and am thinking of keeping them so I can spread out the cost of putting truetracs in both ends. If I did change I'd probably go to 4.10's as I liked the way it drove when I had 31's and 3.73's. I don't do rocks and have enough power with 33's (to put it in perspective I can pull up a decent grade in 5th on the highway without thinking of downshifting). 4.56's wouldn't help me for driving around town but a lower crawl speed would be nice, than again I could use 4L. |
#30 |
Truetracs don't multiply torque, they just help utilize/take advantage of/access a larger percentage of what's available at the driveshaft. It's only a torque converter in an automatic transmission that actually does torque multiplication.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
