True 5" Fender Flare for TJ - JeepForum.com
post #1 of 5 Old 11-30-2008, 05:47 PM Thread Starter
Steve N
Do any of you know of a factory shaped 5" fender flare on the market? I have a '98 TJ Sahara w/ 33 X 10.5's and the OEM flares are lacking about .75". I've looked all over and haven't had any luck, lost $80 sending back some 6 inchers I didn't care for. I'm considering some Xenon flats, can I cut them down?
Thanks for any advice!
Steve N is offline
post #2 of 5 Old 11-30-2008, 05:48 PM
DBLJ
DBLJ's Avatar
Cut the 6" ones down or make your own. There is no 5" fender flare.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #3 of 5 Old 11-30-2008, 06:03 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
rubicon fender flares are as close as you'll get. 4.5" i believe.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 5 Old 11-30-2008, 09:56 PM
Pillswoj
I'm pretty sure the Rubicon flares are the swame width as the Sahara flares he has, both are wider then stock.
Friends don't let Friends run Bosch
Pillswoj is offline
post #5 of 5 Old 12-01-2008, 07:54 PM Thread Starter
Steve N
Thanks guys, yes the Sahara's flares are wider than other models. Looks like I'll be trying my hand at cutting down some 6" flares. I may try to set my tires back in by going with a 4" backspace on my wheels, I'm currently running 3". On the other hand I may just leave 'em as is and try to get numb to slinging winter crud up & down the sides of it! I don't know if I can get used to that...
Steve N is offline
Fender Flare "nutserts" just spinning, What now? yellowjp79 TJ Wrangler Technical Forum 8 05-29-2009 10:47 PM
7" fender flare, your .02? bc yj'er YJ Wrangler Technical Forum 25 03-30-2007 06:28 PM
"bolt-on" fender flare installation advice blake989 YJ Wrangler Technical Forum 12 05-05-2006 09:47 PM
Front Fender Flare Extention Things...Do I "Need" them? EerieStrayer TJ Wrangler Technical Forum 1 10-01-2005 12:18 PM
6" fender flare question raZe YJ Wrangler Technical Forum 1 11-12-2004 08:59 PM
