Trouble Starting Jeep - JeepForum.com
post #1 of 3 Old 09-18-2004, 03:24 PM Thread Starter
Snowman01TJ
I have a 01 TJ that doesn't like to start.
Temperature has nothing to do with this problem. In the morning is doesn't like to start, if I take it to the store and am in the store for 5 minutes it doesn't like to start. Today it got worse.
Today it finally started after about 6 tries. I went about 5 miles down the road went in the store and when I got out, the same thing. 5 or 6 turns of the key and it finally started.
It seems to be getting worse.
Please help before I get stranded somewhere!!
Snowman
Blue Jeep Club Member #30
Hurricane Jeep Club Member #3
2001 Wrangler Sport 4.0L
Teraflex 3T
Mickey Thompson Classic II
BFG AT KO 33X12.50
Snowman01TJ is offline
post #2 of 3 Old 09-18-2004, 03:27 PM
ProfessorCRX
ProfessorCRX's Avatar
It's kinda hard to diagnose sitting at a computer. It sould be an air, fuel, or spark problem. How long has it been since you changed your air filter? How are your plugs and wires looking?
ProfessorCRX is offline
post #3 of 3 Old 09-18-2004, 03:40 PM
JeepKidd
Hey,
I have had the same problem. Crank the engine for only 15 seconds at a time, no longer! If that doesnt work after 2 trys, what helps is to press the gas all the way in, start cranking the engine, then pull the gas out. It should catch. I was told it was either the fuel pump or the fuel pressurizer. Personally, im not going to spend $500, or whatever it would cost, to have my fuel pump fixed if i can get my jeep started, even if i do have to press the gas in everytime. Instant Message me if you have anymore questions, i think we are experiencing the same problem.
Hurricane Jeep Club Member # 4
Under 18 Jeep Club Member # 5
Green Jeep Club Member # 127
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Hella 500 Driving Lighs
2 Delta Fog Lights
JeepKidd is offline
Jeep starting trouble 93jeepREDSOX YJ Wrangler Technical Forum 8 03-20-2017 05:41 AM
Jeep has trouble starting dmico76 TJ Wrangler Technical Forum 3 08-22-2009 07:37 PM
2004 Jeep Has trouble starting!!!!!!!!!!! TCzyzak Wrangler General Discussion 14 04-02-2009 06:58 AM
95 jeep trouble starting meanstreak02 YJ Wrangler Technical Forum 2 10-27-2008 10:11 AM
Jeep has trouble starting GLADIATORTJ TJ Wrangler Technical Forum 2 06-24-2004 12:04 PM
