Trouble shifting into 2nd and 4th - JeepForum.com
post #1 of 4 Old 11-08-2010, 01:52 PM Thread Starter
mtgctsgta
99 Wrangler Sahara (4L engine with AX15 Trans)
174,xxx miles
Just replaced the trans with a rebuilt one from a reputable shop, along with new clutch kit.
- Sometimes 2nd and 4th will go in ok
- Other times, it'll grind when trying to shift into them (with fully pressed in clutch)
- and even other times, itll go in, but I wont know it. (Feels muddy - I put it in but I have to keep pulling untill I feel the shifter not moving anymore, and I can't tell it actually engauged untill I let go of the clutch and feel if there is load on it)
1,3,and 5 Feel perfect, go in fine, and I can tell it shifted into gear (reverse mostly fine)
I can also hear a new sound during idle, when no gear is enguaged and clutch is not pressed in. (When clutch is pressed sound goes away)
- I think that this is unrellated to the main issue, but I figured I would throw it in (Heard this is normal on all wranglers, expecially ones newer, or with newer trans parts, like mine)
My ideas so far,
- 1. Replace the fluid in the AX15 with synchromesh (Currenly used PX3 Brand gear oil from O'Rielys - compatible, but i hear nothing but good about synchromesh / redline here) - Dont think this will fix everyhing, becuase 1,3,and 5 are perfect
- 2. Clutch master may need to be bled (What are some symptoms that help me determine if this needs to be done?)
- 3. Issue with the shifter - Any idea what to look for here?
Thanks.
mtgctsgta is offline
post #2 of 4 Old 11-08-2010, 01:58 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
Take it back to the shop if there's a warranty on the work.A shifter issue would only be because of a BL or t case drop.The Redline MT-90 won't help.
p.s. Fill out your profile for better answers in the future.
TheBoogieman is offline
post #3 of 4 Old 11-08-2010, 06:17 PM
athlon12
Bump
Thanks, I'm trying to avoid removal of the trans again, this is my DD and the shop that built the trans is about 3 hours each way.
Anyone else have input on any of my questions?
athlon12 is offline
post #4 of 4 Old 11-08-2010, 06:22 PM
athlon12
Apparently I remembered my old accounts password too
athlon12 is offline
2nd gear , 4th gear , ax15 , grinding , transmission
trouble shifting from N-1-2, need help jeepgrunt1072 TJ Wrangler Technical Forum 15 02-01-2010 10:12 PM
Trouble Shifting Miles TJ Wrangler Technical Forum 13 07-29-2009 11:06 AM
Trouble shifting r1627 YJ Wrangler Technical Forum 10 09-28-2008 12:42 PM
shifting trouble- AX5 deaconjeep YJ Wrangler Technical Forum 9 04-24-2008 09:44 PM
Trouble shifting, please help! Marty315 TJ Wrangler Technical Forum 6 11-09-2006 01:12 AM
