Quantcast trouble removing my shocks - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > trouble removing my shocks
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 01-31-2008, 10:50 AM   #1
langston.4
im trying to remove my front shocks so i can replace them, but i cant get them off. i cant keep the stem from turning. i have the correct size open ended wrench, and i can unscrew the nut a little bit, but when it gets to the rusted part, the whole thing turns, stripping out the top of the stem. ive sprayed it for a few days with wd-40 and pb blaster. im having someone come over later 2day with a blow torch to warm it up, but im out of ideas? anyone have a lot of trouble with their shocks? what did you do?
thanks
http://www.jeepiki.com/
I want an official Red Ryder, carbine action, two-hundred shot range model air rifle!
langston.4 is offline   Reply With Quote
Old 01-31-2008, 10:55 AM   #2
msavard
Cutting Wheel + New Bolts
2004 Yellow TJ Sport
(purchased stock on 6.3.06)
4.0L Auto • 35" Maxxis Bighorns • D30/D44 w 4.88 Gears • 2.5" OME LJ/XJ lift • JKS Trackbars • Brown Dog MML • 1" BL • Warn Engine Skid • Aussie Locker (FR) / Rubi Air Locker (REAR) • SYE/CV • Nth Adj Control Arms • Bestop Oversize Tire Carrier • PSC Rocker Knockers • ORO Swayloc • TNT Tube Fenders
MIDSOUTH JEEP CLUB > Jeepers from TN, AR, MS, and KY
msavard is offline   Reply With Quote
Old 01-31-2008, 10:57 AM   #3
safarimike
I took a cut off wheel and notched the shock shaft (I guess you would call it that) and then was able to hold it with a pair of vice grips. Might be able to hold it with vice grips without notching it too.
1999 Jeep Wrangler Sport
safarimike is offline   Reply With Quote
Old 01-31-2008, 10:58 AM   #4
JJs99TJ
Do you plan on keeping or reselling your old/current shocks?
If not, your new shocks should have all new hardware, right?
When your friend with a torch comes over, if the heat doesnt
help it out, just cut it off completely
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline   Reply With Quote
Old 01-31-2008, 11:01 AM   #5
Trebor
provided your not re-using(selling) any of the old shock, tighten it down as much as possible, then hacksaw off the just above the nut. then when you attempt to remove the nut you never get to the rusted part of the thread because you have already cut that off. just an idea but i thought it could help.
Bobby T...Out!!!
Trebor is offline   Reply With Quote
Old 01-31-2008, 12:08 PM   #6
ROUGHSHOD
I had the same problem when I first swapped out my front shocks. Solution was to clamp a pair of vise-grips on the piston of the shock. As you turn the nut on top, the vise-grips will swing until they contact the shock tower. As soon as they do, if you have them on tight enough, you'll be able to get the nut the rest of the way off.
ROUGHSHOD is offline   Reply With Quote
Old 01-31-2008, 12:19 PM   #7
1CleanTJ
wire brush or wire wheel the rusted threads above the nut and if you have any anti-sieze, brush a little of that on. It makes a big difference, allowing the the nut to glide over the rust. If youve ever taken a real stubborn nut off of rusted thread at the end you'll feel how hot it gets from plowing through all the rust
1CleanTJ is offline   Reply With Quote
Old 01-31-2008, 12:26 PM   #8
Crashnburn80
After hours of messing with it, I did the above as well.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Old 01-31-2008, 02:16 PM   #9
djt283
http://www.quadratec.com/products/92810_202.htm
Wish I bought these before I did mine. The access holes on top are there for a reason. I bet with these you'd be able to hold the nut tight enough to get it off past the rust.
If you can loosen the nut a little, try to get a needle nose vice grip between the nut and the top of the bracket. Then you can grip the threads to stop the shaft from turning.
I just cut mine off.
djt283 is offline   Reply With Quote
Old 01-31-2008, 02:46 PM   #10
lynn
Before I removed the stock shocks on my LJ, I bought the shock nut removal tool from 4WDH.
http://www.4wd.com/productdetails.aspx?partID=15179
Worked perfectly.
Lynn
'05 LJ
EarlyCJ5.com Forums
lynn is offline   Reply With Quote
Old 01-31-2008, 05:00 PM   #11
phydeaux
I just took the bottom bolts off and then worked the whole shock back and forth until the top broke off. Works if you're not going to use them again, right?
'98 TJ Sport, 4.0, 5 spd., 3.73's; 4" RC Series II Lift; 33's, Daily Driver.
Life Member Hummer Recovery Team.
Just
Empty
Every
Pocket
phydeaux is offline   Reply With Quote
Old 01-31-2008, 05:59 PM   #12
BENG
Greetings from a lurking Jeeper with new shocks.
The best 60 bucks I ever spent was paid to the dealer to remove and replace my 150,000-mile OEM shocks. I provided the replacements and they provided the labor. No more cussing and swearing for me when the shaft just spins as I turn the nut, the mechanic put his super hi-speed 3/8" impact on the front top nuts (through the access hole) and in 3 seconds the impact speed outspun the rotating shaft and the nuts zipped right off. Even I was impressed at that move!
Then he spent the next half hour drilling out and tapping the back left upper shock mount, against the gas tank, after breaking that bolt.
I'll tell ya, I won't even hesitate anymore when they tell me 15 bucks per shock to R and R!
I hope this helps someone...
BENG is offline   Reply With Quote
Old 01-31-2008, 06:06 PM   #13
.Jch.
I don't see the big fuss over shocks and the hassle with them spinning. Just have someone hold the shock while you use a deep socket on the top bolt. Changing shocks is maybe a 5 minute job per shock.
[SIZE="4"][CENTER]
[B]_____
[U]l JEEP l[/U]
[U]OllllllllO[/U][/B]
[SIZE="1"]2006 Unlimited[/SIZE][/CENTER][/SIZE]
[center][B]Black Jeep Club V2.0 Member #2006
[URL="http://groups.jeepforum.com/LJ_Owners"]LJ Owners, join the group and click here.[/URL][/B][/center]
.Jch. is offline   Reply With Quote
Old 01-31-2008, 07:55 PM   #14
ROUGHSHOD
The piston will still spin if you're just holding the tube. And If you've truly got a stuck nut, no one is gonna be able to prevent the piston from spinning just by holding it.
Old 01-31-2008, 08:08 PM   #15
jcm11881
I second that. If you dont plan on reusing the old shocks, then remove the bottom bolts, then just stand on something like a milk crate and pull up on the shock until it snaps. Its the easiest and quickest way, and wont damage the shock mount. I've done it 4 different times.
jcm11881 is offline   Reply With Quote
Glock Forum
