Quantcast trouble removing hard top - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > trouble removing hard top
Old 10-10-2006, 10:17 PM   #1
kangarool
Hi everyone, my first post, and I should caveat, I am mechanically inept
I am simply trying to remove my Hard Top on my 2005 Jeep Wrangler Renegade. In order to remove the hard top, I am supposed to disconnect the washer hose, by disconnecting the wire harness from the hard top, by pressing the tab and pulling the connector to disconnect. It won’t come off nor can I press the tab… it appears that the “red lock” is locked.
The manual says to “push the red latch to the right, until you can only see the latch on one end (right) of the connector. This will unlock the connector tab.”
I can’t manage to unlock the red lock, push it, move it, anything. Can anyone provide any help? I can supply any other information if it helps.
Cheers/Kanga
kangarool is offline   Reply With Quote
Old 10-10-2006, 10:24 PM   #2
Andrew F
I had to use a flat head screw driver to move my tab.
04 LJ
4.5 RE SF w/ 3.5 springs
32x11.50R15 BFG MT
4.88, Lock Right F/R
[SIZE="2"][COLOR="Red"]Red Jeep Club Member #347[/COLOR][/SIZE]
Andrew F is offline   Reply With Quote
Old 10-10-2006, 10:24 PM   #3
Rocky529
Jeep
Rocky529's Avatar
I hate those tabs that are all over the TJ
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 10-10-2006, 10:26 PM   #4
kangarool
thanks... did you just sort of pry it into the red lock, and pop it over/off?
Old 10-10-2006, 10:32 PM   #5
Rocky529
Jeep
Rocky529's Avatar
Yea, watch your fingers though... I stabbed myself once.
Old 10-10-2006, 10:51 PM   #6
Jeeper X
Yep, that was a pain the first time I took mine off too. Like the others, I used a flat screwdriver. After the first time you won't need to mess with that red tab again. Just leave it in the open position. Then you'll just slide it off and on when you take your top off and on.
Here's a close up just in case that helps
[URL=http://s5.photobucket.com/albums/y181/JeeperX/]My '04 Black X [/URL]
Jeeper X is offline   Reply With Quote
Old 10-10-2006, 11:55 PM   #7
kangarool
got it off, thanks for the tip. Now for the rest of the removal (and after that, Soft Top replacement...) cheers/Kanga
Old 10-11-2006, 01:20 AM   #8
NEWtoTHEjeepLIF
Next time just pull it.
NEWtoTHEjeepLIF is offline   Reply With Quote
Old 10-12-2006, 01:54 AM   #9
kangarool
OK, one more question. Got the hard top off, no problem. Got the soft top on, basically no problem after a couple hiccups. It's all working... only question is, everytime I want to take the soft top back (but not remove it all together) do I have to remove the two side-read windows, and the full rear window?
Old 10-12-2006, 02:29 AM   #10
NEWtoTHEjeepLIF
If you don't want to ruin them yes. Most run it without those windows the majority of the time. Some just run the hardtop or nothing. Some take them out everytime (we call them "the type with time to kill")
Old 10-12-2006, 02:41 AM   #11
Awshux
Cynical Bastard
Awshux's Avatar
Take the windows out if you want them to last any amount of time and roll them up or lay them flat for storage. Otherwise they get creases and eventually cracks in them.
You live and learn. At any rate, you live.
-Douglas Adams
Awshux is offline   Reply With Quote
Old 04-21-2009, 01:32 PM   #12
UKFan4Sure!
That $%^&* connector is a PITA!! I was sooooo mad after about 20 minutes of fighting "innovative engineering" at it worse (and actually breaking the tab off) that I popped out the housing for the connector, turned it toward me ONLY to see the red locking tab and curse out loud. I thought, "you have GOT to be kidding me".
No mention of this locking tab anywhere in the owner's manual whatsoever. What a crappy design. The epitome of stupid.
UKFan4Sure! is offline   Reply With Quote
Old 04-21-2009, 03:12 PM   #13
Mini-Me26
I'd check the post dates when exploring threads.
Mini-Me26 is offline   Reply With Quote
Glock Forum
