Trouble Code PO138 - JeepForum.com
post #1 of 13 Old 06-29-2006, 05:36 PM Thread Starter
Flyusaf2002
Trouble Code PO138
Hi all,
The code that came up on my 99 TJ 2.5 is a PO138 - "THe input voltage from O2 Sensor number 2 in Bank 1 is too high for current operating conditions". Can anyone give me some information on this problem?
Can I still drive my jeep - it run just fine, maybe a bit rough at idle, but otherwise seems okay. If I get to this problem in a few weeks, have I waited too long/am I causing long term damage to my jeep?
I appreciate help, I'm currently going through a military school and have very limited time, so I'd love to delay launching into the project for a few weeks.
Thanks,
Andy
STEEL CITY JEEP CLUB MEMBER # 17
99 Green TJ "Gracie" SOLD
2001 Red WJ "Ginger"
Flyusaf2002 is offline
post #2 of 13 Old 06-29-2006, 05:53 PM
Jetmech143
Replace the sensor???
2002 TJ Sport 4.0 Sylver
2.5 in Rancho Susp. Lift, JKS Front Discos
31x10.5 BFG AT's, Cold Air Intake, W/S mounted Daylighters, MM Winch on Tomken plate with light hoop, Bikini/Windjammer/Duster Year round!
Jetmech143 is offline
post #3 of 13 Old 06-29-2006, 06:02 PM Thread Starter
Flyusaf2002
I don't know understand whether or not the sensor is broken and the engine is fine, or, the sensor is accurate and somthing is seriously wrong with the engine? Does anyone have any better detail than the simple diagnosis from the code reader?
Thanks,
Andy
post #4 of 13 Old 06-29-2006, 06:43 PM
Slithering_Joe
Not sure if this helps but mine once in a while will store this code as a pending code which will not illuminate the Check Engine Lamp (CEL). All readiness monitors check out OK though. By the next day the pending code is gone. And yes, the CEL does work. This code should not casue a driveability problem such as a rough idle. That sensor in question monitors the catalytic convertor.
Did your CEL illuminate?
Edit: The description I have is "...O2 sensor shorted HI." In the scope of things, I'm not sure what that really means. A short brings the voltage low.
4.0L TJ
Slithering_Joe is offline
post #5 of 13 Old 06-29-2006, 06:46 PM Thread Starter
Flyusaf2002
Yes, my Check Engine Light is on steady. Also, the Catalytic Converter is relativly new - dealer installed (warranty) approximatly a year ago.
Andy
post #6 of 13 Old 06-29-2006, 06:55 PM
Slithering_Joe
If you have mileage above 60,000 miles it could be a bad O2 sensor. You may want to check the resistance in the wiring from the PCM down to the O2 sensor. A high resistance will show a break/open circuit or a corroded wire in the harness. I'm mentioning this as a possible test to avoid throwing parts at the problem.
According to a Chrysler '98 Service manual:
PCM, BLK Connector
PIN WIRE DESCRIPTION
A25 TAN/WHT O2 Sensor SIGNAL (*)
A4 BRN/YEL SENSOR GROUND/RETURN (*)
DOWNSTREAM O2 sensor connector
TAN/WHT O2 Sensor SIGNAL (see * above)
BRN/YEL SENSOR GROUND/RETURN (see ** above)
FUSE 21 (20A) feeds ORG/DK GRN wire to the 12V+ heater circuit on O2 Sensor
BLK wire GROUNDS O2 Sensor Heater Circuit
4.0L TJ
post #7 of 13 Old 06-29-2006, 06:58 PM Thread Starter
Flyusaf2002
Thanks joe - I've got 56000 miles, so i'm right up close to that border. Does Anybody have an idea what the cost of a new 02 sensor is?
Andy
post #8 of 13 Old 06-29-2006, 07:05 PM
Slithering_Joe
Andy
They range about $60 to $100. Don't buy Bosch! Get Mopar (OE) or Denso.
maybe check www.oxygensensors.com I have no experience with them. just popped into my head.
For the downstream O2, I got 95,000 on my TJ and 107,000 miles on my Mustang. Since my Mustang has homemade MIL Eliminators I guess that doesn't count.
PS: Don't buy Bosch brand.
4.0L TJ
post #9 of 13 Old 06-29-2006, 07:15 PM Thread Starter
Flyusaf2002
Verdict?
So, what's the verdict, can this problem wait a few days (and about 150 miles) or must it be done tomorrow? Again, the idle shows only the smallest rough spots, and the jeep drives just fine, however, the CEL light is remaining on constantly.
Thanks for all the help,
Andy
post #10 of 13 Old 06-29-2006, 07:23 PM
Slithering_Joe
Andy
I think you are fine. If you have a short than I would get it fixed as soon as possible. Don't be alarmed. The PCM has a lot of protection built into it. Your idle has nothing to do with the problem you are having on the downstream O2 sensor (aka O2 Sensor 2). It just monitors the catalytic convertor.
One thing though, if the Cat was replaced under factory warranty, the O2 sensor and all the way up to the PCM should also be covered!
4.0L TJ
post #11 of 13 Old 06-30-2006, 07:34 AM Thread Starter
Flyusaf2002
My jeep is a 99, I believe that thewarranty that would cover such a fix only lasted for 6 years/60,000 miles. While i'm within the miles, I'm over on years. Did my warranty get extended when they installed a new Cat?
Lastly - is this a problem that I should let a dealer look at, or can any midas,monroe,mastercare give me a hand on it? Thanks for the help,
Andy
post #12 of 13 Old 06-30-2006, 09:31 AM
scottheath5499
You can forget the warranty. Also, you can drive the Jeep. The downstream O2 sensor monitors your emissions. You most likely have a bad O2 sensor. They simply screw into your exhaust pipe just after your CAT. 7/8" wrench. Buy one from the dealer at about $100 and replace it yourself. Disconnect the negative lead on your battery for about 10 minutes to clear the CEL. Good to go!
scottheath5499 is offline
post #13 of 13 Old 06-30-2006, 10:09 AM
Slithering_Joe
Let us know what you did to fix the problem.
Check engine light on. PO138 Code? jcoker TJ Wrangler Technical Forum 2 12-15-2009 12:43 PM
442 trouble code TJ--help nmwranglerx TJ Wrangler Technical Forum 4 05-10-2008 11:30 AM
MAP trouble code CLiP68 YJ Wrangler Technical Forum 3 11-29-2007 02:41 PM
sorry for being the 900th trouble code post but i couldnt find what code 24 was shurd25 YJ Wrangler Technical Forum 3 03-24-2007 08:25 AM
Trouble Code 51 scottheath5499 TJ Wrangler Technical Forum 9 05-04-2006 11:08 AM
