Tricks for Installing Shocks - JeepForum.com
post #1 of 30 Old 11-28-2007, 07:15 PM Thread Starter
bulldietz
I'm putting front and rear shocks on my 2000 Wrangler and was just wondering if there are any special tools or any tricks to getting the job done?
bulldietz is offline
post #2 of 30 Old 11-28-2007, 07:21 PM
ptowntj
ptowntj's Avatar
Bar pin eliminators will save you some time and frustration, but if you opt out of those a vise and a big hammer is nice. You will have to grease up the bar pin and pound it in, I actually had to grind a bit off...I went to bar pin eliminators a couple weeks later. JKS makes some nice ones.
8 lug xj.
ptowntj is offline
post #3 of 30 Old 11-28-2007, 07:41 PM
Rocky529
Rocky529's Avatar
PB Blaster on your old shock bolts a couple of days before the install.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #4 of 30 Old 11-28-2007, 08:00 PM
cvd
cvd's Avatar
Here is a good write up on installing a BB, which is shocks and spacers (above the springs). Ignore the part about the spacers.
http://www.4x4xplor.com/REBB.html
cvd is offline
post #5 of 30 Old 11-29-2007, 09:52 AM
SpeedyMitch
SpeedyMitch's Avatar
I found that jacking up the *frame* (not the axle) of the Jeep >a few inches< allows you to install the new shock without having to hold it compressed while you get the bolts in place.
Replacing the rear shocks is very simple on the Wrangler.
Speedy
SpeedyMitch is offline
post #6 of 30 Old 11-29-2007, 10:13 AM
Mr. Joshua
Mr. Joshua's Avatar
a little anti-seize compound on the bolts will help you out next time you replace shocks...
2001 TJ 60th Anniversary Ed.
Cragar 342 series steel wheels
31" BFG A/T's
SkyJacker Hydro's
Olympic Grill Guard
Tuffy Glovebox
POLISH JEEP OWNERS CLUB #5
Parrothead Jeepers union member #11
Mr. Joshua is offline
post #7 of 30 Old 11-29-2007, 10:18 AM
CBird77
Its an easy job. Just spray PB Blaster on the rear upper bolts for a few days as well as the rest of the hardware.
Bird - 2006 Unlimited 2004 Limited 4x4 KJ
CBird77 is offline
post #8 of 30 Old 11-29-2007, 10:23 AM
beryl
a long extension helps for the rear. i used a 12" extension and it worked great. had no problems reaching the bolts and was done very quick.
Bar pin elminators will indeed save you from having to put the bar pin in the shock which is nice...but i got some bar pin eliminators for my stock shocks and getting out the bar pin to install the BPE's was a huge pain.
the front is easy too. you may need a box end/open end wrench for the top nut on the front passenger shock as there is no hole to reach the top nut like on the driver side.
06x-6speed...hard/soft top, BPE's, 2" coils, 1" PA BL, 32 bfg mt's, 15x8 MT alloys, big daddy rocker guards, flowmaster, RE gen II discos, rear bumper and tire carrier, 10" MTX sub with 800watt kenwood amp, mossy oak mats, sony stereo
beryl is offline
post #9 of 30 Old 11-29-2007, 10:30 AM
RockRunner85
Use anti-seize and bar pin eliminators. If you don't mind pounding in the bar pins then thats fine for the front. However on the rear the shock will slip sideways on the bar pin and clank around. To not have to do it twice buy the bar pin eliminators for the rear. JKS makes some nice ones.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #10 of 30 Old 11-29-2007, 10:35 AM
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
X2 on the bpe from jks, i'm running them all around an i like them. As for the shocks, a jack can be usefull to compress the shocks for the installation.
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline
post #11 of 30 Old 11-29-2007, 10:39 AM
beryl
i never heard a clank before i had bar pins...i guess some do though.
i got some dish soap and the bar pins weren't too bad...just had to cram them in with my hand. a vise helps though.
beryl is offline
post #12 of 30 Old 11-29-2007, 10:46 AM
RockRunner85
Depends on how you use the Jeep. Over time the sideways force of off roading will move the shock bushing off the center of the bar pin. That leaves play and you get the clanking.
post #13 of 30 Old 11-29-2007, 10:53 AM
beryl
street, with mostly hill climbs and some rocks and i used to do some mud and water...
rockcrawler.com said they also had this problem with the rear shocks though...
beryl is offline
post #14 of 30 Old 11-29-2007, 11:20 AM
CrzyWhtBy
CrzyWhtBy's Avatar
Bar pin eliminators are the way to go...I don't have them and and have had to replace the bushings on the shock twice now. I actually have one clanging around right now. They come out when you do any kind of wheeling...probably fine if you are just driving to the mall though.
"Early to finish...Late to start"
CrzyWhtBy is offline
post #15 of 30 Old 11-29-2007, 12:15 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Never had any of that on my TJ in 174,000 miles & plenty of very tough trails.
Gone wheeling Friday through Sunday.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
need help installing new shocks toneloc3131 YJ Wrangler Technical Forum 1 06-10-2009 09:21 PM
Any "tricks" for installing new control arms? JeepRat TJ Wrangler Technical Forum 7 05-12-2009 12:49 PM
any tricks for installing shocks abcmatthew JK Wrangler Technical Forum 7 02-25-2009 12:27 PM
TRicks to installing carrier shims? d35 farmer-dave TJ Wrangler Technical Forum 2 09-15-2005 07:25 PM
Installing new shocks NEED HELP!!! smileyox TJ Wrangler Technical Forum 11 04-10-2005 08:17 AM
