TRE flip in need of a 7 degree reamer - JeepForum.com
post #1 of 18 Old 05-09-2013, 08:02 AM Thread Starter
rambo3489
Hey guys,
I am wanting to flip my TRE on my 44. But the reamer is quite expensive. Any chance one of my fellow jeepers has one they could lend me?
Thanks
Tyler
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #2 of 18 Old 05-09-2013, 08:05 AM
NotURMailman
NotURMailman's Avatar
Look on the Black Magic Brakes website in the "Jeep Co-op" section. I believe you wil find inserts there that wil not require a reemer.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 18 Old 05-09-2013, 08:08 AM
NotURMailman
I may have been confused... I just looked and didn't see them?
I know I've seen them somewhere.
post #4 of 18 Old 05-09-2013, 08:53 AM
rchase559
They're still there and can be found on this page
http://blackmagicbrakes.com/site/414...Co-Op.php#2864
Unless you are using a TRE with a larger tapered stud, you cannot just run a tapered ream in through the top and call it a day. You will end up with the bottom half of the taper being too big and not contacting the TRE.
rchase559 is offline
post #5 of 18 Old 05-09-2013, 09:21 AM Thread Starter
rambo3489
Thanks guys! Exactly what I need.
Sent from my phone because I'm doing something "more important"
<a href="
THE YJ MY WAY</a>
post #6 of 18 Old 05-09-2013, 09:29 AM Thread Starter
rambo3489
However that is for a TJ D44. Anyone know if it will work on a Ford D44? Or anyone know the size or part number of the TJ TRE so I can cross reference it?
<a href="
THE YJ MY WAY</a>
post #7 of 18 Old 05-09-2013, 09:31 AM
NotURMailman
MOOG-ES3094L
MOOG-ES3095R
Those are the part #s for a TJ.
What Ford did the axle come from?
post #8 of 18 Old 05-09-2013, 10:03 AM Thread Starter
rambo3489
Thanks. 78 f150
<a href="
THE YJ MY WAY</a>
post #9 of 18 Old 05-09-2013, 10:08 AM
NotURMailman
MOOG-ES2064L
For the Ford.
post #10 of 18 Old 05-09-2013, 10:11 AM
NotURMailman
Not the same taper...
Jeep -
Stud Small Taper .558
Stud Large TaperStud Thread Dimensions .626
Ford -
Stud Small Taper .662
Stud Large Taper .776
post #11 of 18 Old 05-09-2013, 10:40 AM Thread Starter
rambo3489
Crap! Maybe I run it under n build a beefier tie rod then
<a href="
THE YJ MY WAY</a>
post #12 of 18 Old 05-09-2013, 10:49 AM
NotURMailman
I'm sure someone could make you some inserts for the Ford knuckles to accept Currie tie rod ends. Are you narrowing the axle to TJ width?
post #13 of 18 Old 05-09-2013, 11:17 AM Thread Starter
rambo3489
No. Going full width
<a href="
THE YJ MY WAY</a>
post #14 of 18 Old 05-09-2013, 11:21 AM
NotURMailman
Then I wouldn't go to TJ taper anyway.
Google around, I'm sure you can find inserts for your large taper knuckles. Or you can get different knuckles.
post #15 of 18 Old 05-09-2013, 12:10 PM Thread Starter
rambo3489
Yea I'm gonna keep the extra beef. Where did you find the moog part numbers and dimensions? Any chance you have the number or specs on a D60 taper?!
<a href="
THE YJ MY WAY</a>
