traveling with soft top inside soft top
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |
Hey quick q....I'm getting a new soft top. i already have one on now. Would i be able to fit a soft top w/all hardware inside of my jeep??
Thanx ![]()
[COLOR=deepskyblue][B]97 Wrangler TJ 2.5L I4 5spd[/B][/COLOR] [COLOR=white][B]White Jeep Club Member #70[/B][/COLOR] [COLOR=silver]97 Jeep Club Member #11[/COLOR] My Jeep Pics: http://www.imagestation.com/album/?id=4288276679 Or..if you're anti-imgstation: [URL]http://www.cardomain.com/id/tjen97[/URL] |
#2 |
Are you getting all new hardware too or just the fabric + windows + plastic surrounds?
I would think that it might be a tight squeeze if you're getting all the bows but then again you might be able to do it if you put your soft top down and stuff..
2010 Sahara |
#3 |
huh? whatcha mean? id assume if youre runnin a S/T now and youre puttin a new one on youd have to disconnect the spreader bars attached to the rollcage from the old S/T to properly attach the new one. if youre askin if they physically fit one over another - then yea id guess that they would - im runnin my H/T w/ my S/T folded down and tucked away.
and i think most of the replace a tops will work w/ factory S/T hardware.
_____________________O|||||O______________________ [FONT=comic sans ms][COLOR=red]RED JEEP CLUB MEMBER #70[/COLOR][/FONT] ~ [COLOR=darkred]FM2CD Jeep Club Member #007[/COLOR] 1998 Sport Flame Red with some stuff... now with cruise control!! [URL=http://www.imagestation.com/album/?id=4288497535]paragon 112203[/URL] |
#4 |
Admin, Jeep in Pieces
I bought a factory soft top frame and went to pick it up with my hard top on. Naturally I couldnt put it the way it would normally sit, but with the back seat down (not flipped) and contorting one of the sides up between the space between the front seats and into the passenger seat, I was able to drive it home. Took a little bit to figure out, but its doable.
You can do things the right way or the wrong way. Or you can do it MY way...which is like the wrong way, only faster. Ramsey Winches | My Gallery | www.dakuda.com |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
