Transmission/transfer case fluid - JeepForum.com
post #1 of 6 Old 08-19-2017, 09:40 AM Thread Starter
rjcobra
My 1998 TJ has only 60k miles on it. I don't believe the manual transmission fluid or transfer case fluid has ever been changed. Should I do it just because of the age of the jeep? What about the differential fluid. It has not seen any abuse.
1998 Wrangler SE
31 x 10.5 BFG AT's on Black Steelies
2003 Mustang Cobra, some performance goodies,
490 rwhp/456 rwtq
rjcobra is offline
post #2 of 6 Old 08-19-2017, 11:26 AM
Shark_13
Yes, all those fluids should be changed if they have never been done that you know of. (Almost 20 years!!)
Also your coolant, brake fluid, and power steering, if they have never been flushed.
Shark_13 is offline
post #3 of 6 Old 08-19-2017, 11:57 AM
hokahay
Engine oil, oil filter, air filter, spark plugs, differential oil, accessory belt.
Probably the muffler bearing and the radiator belt while you are at it.
hokahay is offline
post #4 of 6 Old 08-19-2017, 06:09 PM
DylanC7410
You could also straight pipe it so you dont have to replace the muffler bearings because those could be a pain the *** and you still would have to change them out later when they wear out again, just take the muffler off and call it a day especially if you live down here in FL
DylanC7410 is offline
post #5 of 6 Old 08-20-2017, 01:41 PM
2jhanna
Manual, ax5, and t-case are very easy and cheap to change. Tranny can use a couple qts of synthetic 10/30 motor oil, and t-case any ATF, as it is not picky.
Both are drain and fill gear boxes. Although a couple of special tools are needed. Make sure you loosen the fill plug before draining.
Consider changing axle gear oil also.
jhanna
denton county, tx
2jhanna is offline
post #6 of 6 Old 08-20-2017, 08:57 PM
MoFarmBoy
Just assume the PO was a cheap, hard-driving, abusive owner. So change out everything. Seriously.
MoFarmBoy is offline
