Transmission Swap? - JeepForum.com
post #1 of 6 Old 08-03-2011, 03:11 PM Thread Starter
Threlkeld
Transmission Swap?
It's it easy/possible to put a 6-speed transmission from an 05/06 TJ into a older model (99) 5-speed TJ?
I couldn't really find any good threads on the subject.
Threlkeld is offline
post #2 of 6 Old 08-04-2011, 01:21 PM
mpyusko
The spline count is different for 4 vs 6cyl. The gearing inside the transmission is also different. Spline count on the tcase is another issue. All things being 6cyl you should more than likely be fine. I would google dimensions to see if there are length differences, and another good way to tell is if there are adapters made for the swap. But honestly you should be fine.
-mpyusko
_________
'97 SE Black, 4cyl/5spd, Soft top, Jeeperman Rear Bumper, 33x12.5x15 Trxus M/T's, 4" Lift, 1" JKS MML
BLACK JEEP Club V2.0 #84
Rust-Bucket Build-Ups Club Member
mpyusko is offline
post #3 of 6 Old 05-13-2012, 04:48 PM
caputod
im trying to find that out right now
White Jeep Club Member #58
caputod is offline
post #4 of 6 Old 05-13-2012, 05:16 PM
DevilDogDoc
Why would you want to? The AX-15 is a better tranny, NV has gone bankrupt, Aisin still makes them and they have parts available to fix them. That should tell you something right there.....
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #5 of 6 Old 05-13-2012, 07:06 PM
DivineKaos
I was under the impression that the 3550 was a more stout transmission?
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
post #6 of 6 Old 05-13-2012, 07:16 PM
cfmiller58
the 3550 is not a more stout transmission. they are about equal and there is no advantage to swapping to one or the other. it has been discussed on here several times, so finding some references should not be too difficult. there are also swap threads to the 6 speed tranny, but as others have mentioned. the ax15 is more preferred anyways in terms of reliability.
Black Jeep Society
cfmiller58 is offline
tj , transmission , wrangler
Transmission swap? Tigger87 YJ Wrangler Technical Forum 10 02-28-2011 10:43 AM
Transmission Swap 99' to my 92' Cardinals033c YJ Wrangler Technical Forum 3 12-08-2009 07:11 PM
Transmission Swap from AX-15 to a ... any help? PhilipSandgren YJ Wrangler Technical Forum 10 04-03-2009 03:55 AM
Which transmission do I need for a swap ? RUBtjICON TJ Wrangler Technical Forum 2 02-10-2009 09:46 AM
Transmission swap bakwoodj2 YJ Wrangler Technical Forum 1 06-16-2005 06:11 AM
