Transmission shakes / binds right before coming to a stop - JeepForum.com
post #1 of 2 Old 01-17-2012, 06:33 AM Thread Starter
sheldonwestwood
Hi,
I have a 2005 4.0L Jeep Wrangler 2dr Unlimited with 6 speed manual transmission.
Recently, when coming to a stop, right around 3-5 mph the transmission will shake / shutter / vibrate for a second, then the car is stopped. It sounds like it is something mechanical binding right under the stick shift. It doesn't matter if the transmission is in neutral, clutch in or out, or in gear with the cluth depressed...
Please, if you have had this problem, or have any suggestions as to what it might be let me know. This is driving me nuts knowing that something is getting torn up inside the tranny.
sheldonwestwood is offline
post #2 of 2 Old 01-17-2012, 11:23 AM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Fill in you profile. Do you have a lift? Did you just purchase this vehicle? Is this something that's been going on for a while?
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
6 speed trans , binding , stick shift , transmission
Stalling out when coming to a stop?? 1993sahara YJ Wrangler Technical Forum 13 11-12-2011 02:57 PM
93 4.0 shuts off when coming to a stop Obcean2 YJ Wrangler Technical Forum 2 02-04-2010 09:54 AM
4.0 stumbles while coming to a stop MTSkull TJ Wrangler Technical Forum 8 12-02-2009 11:54 AM
AX-15 Shakes from stop from 1st and Reverse Yardman Harry TJ Wrangler Technical Forum 4 07-20-2009 07:16 PM
YJ Cuts off when coming to a stop 89 JeepYJ YJ Wrangler Technical Forum 9 07-17-2008 02:46 PM
