Transmission replacement options - JeepForum.com
post #1 of 3 Old 11-24-2004, 02:49 AM Thread Starter
phoen1c1an
My transmission is slipping, probably due to previous owner neglect. I've changed the filter and the fluid, but it still does it sometimes when it's cold and only when I first start it. What options do I have with a 97 TJ that currently has a 3speed auto has far as replacement? I'm looking basically for model numbers. THANKS!
phoen1c1an is offline
post #2 of 3 Old 11-24-2004, 05:36 AM
04 Unlimited
04 Unlimited's Avatar
2015 JK Wrangler
I had a car with an auto trans that started slipping a few years back. Changed the fluid and filter... still slipped. Changed the fluid and filter again and the slipping stopped. Drove the car another 75,000 miles and it never slipped again. Obviously no guarantees, but you might try changing it again. At least it's easier than swapping out a trans.
Hope this helps,
Rich
04 Unlimited is offline
post #3 of 3 Old 11-24-2004, 07:57 AM
Upstate Chili
Upstate Chili's Avatar
I had 2 Jeeps that did the same thing, a 99 TJ with 30,000 and a 95 Grand w/ 100,000, start in up put it in gear step on the gas and it moves very slow at first right?. Talked to a tranny shop and was informed it is a common problem due to under sized seals in the auto tranny. They advised me not to worry about if it was only happening first thing in the morning. Put 50,000 more miles on the GC and 10,000 more on the TJ before i sold them , the problem never got any worse.
Upstate Chili is offline
D30 Replacement Options? SuperWade2 TJ Wrangler Technical Forum 47 04-05-2009 06:09 PM
LJ Transmission options (and SYE q's) sundevilkid TJ Wrangler Technical Forum 2 06-18-2007 01:13 PM
top replacement- options paroxysym TJ Wrangler Technical Forum 3 03-15-2007 08:50 AM
AX5 replacement options. superjoe YJ Wrangler Technical Forum 4 06-27-2005 07:46 PM
Maine Jeepers / AX-5 Transmission replacement options HELP! BigTal YJ Wrangler Technical Forum 3 02-02-2005 07:51 PM
