transmission rear output seal replacement? - JeepForum.com
post #1 of 4 Old 07-23-2005, 04:42 PM Thread Starter
under_psi
anyone replace the rear output shaft seal on their ax15 5sp manual?
first off, is fluid supposed to come out of the rear output seal on the tranny when the tc is removed (tranny is aimed slightly downwards and supported by a jack....)??? i didnt think so, but was just making sure....i have had a tranny fluid leak for a while now, and while doing the SYE decided to inspect and repair it if at all possible.....i ordered and received the seal....so that is all ready and good. i am just not sure as to the next steps....do i have to pull the tailshaft housing piece off of the tranny? or is it a simple pull the seal out and stick a new one in....
it does not look like the easier of teh two ways....looking at the seal, i imagine that i am going to have to do it the hard way....the seal has the pressure spring-ring on it and a lip, making me think that it needs to be installed from the inside....
help? guidance? warnings? all info appreciated.....i sure would liek to drive my jeep sometime soon......
louis
What's coming through is alive. What's holding up is a mirror. But what's singing songs is a snake looking to turn this piss to wine. They're both totally void of hate, but killing me just the same. The snake behind me hisses what my damage could have been. My blood before me begs meopen up my heart again. And I feel this coming over like a storm again. considerately. Venomous voice, tempts me, drains me, bleeds me, leaves me cracked and empty. Drags me down like some sweet gravity.
under_psi is offline
post #2 of 4 Old 07-23-2005, 09:55 PM Thread Starter
under_psi
anyone?
post #3 of 4 Old 07-24-2005, 02:08 AM Thread Starter
under_psi
ttt.......
post #4 of 4 Old 07-24-2005, 09:58 AM Thread Starter
under_psi
well, in case anyone is/was wondering about this, it is very simple...
with the tc removed, use a screwdriver as a prying tool and or a seal puller and simple pull the seal....press the new one in gently, and bang....you are done....very simple fix for something that i thought was going to be tuff....
Rear output seal for SYE same as front output seal? Imped TJ Wrangler Technical Forum 0 10-23-2009 09:57 AM
Transmission Output Seal octovt YJ Wrangler Technical Forum 2 07-16-2006 09:15 PM
rear output yoke seal mikemac4 YJ Wrangler Technical Forum 4 08-18-2005 06:08 PM
SYE rear output seal bigblacktyj TJ Wrangler Technical Forum 1 08-02-2005 09:27 PM
NP-231 Rear Output Seal biohazardbill YJ Wrangler Technical Forum 4 07-26-2004 12:45 PM
