Transmission Noise - JeepForum.com
post #1 of 1 Old 03-04-2008, 07:49 PM Thread Starter
bail315
Transmission Noise
I have a noise coming from my manual transmission. I originally thought it was from the transfer case, however, it is now audible in all gears including 4hi and 4 lo. It happens when the vehicle has been moving and the clutch is depressed. When the clutch is in and the vehicle is at a coast I can hear a chuckling sound, as well as feel the vibrations through the gear shift. It sounds like a sprocket contacting another gear or surface. The noise starts very rapidly and slows down as whatever it is stops spinning. The transmission shifts smoothly through all of the gears and the transfer case engages without issue.
bail315 is offline
Noise from near Transmission jeepyjpsu YJ Wrangler Technical Forum 1 02-15-2010 03:42 PM
Transmission noise? help please. Bloodcraft1987 TJ Wrangler Technical Forum 0 03-01-2009 02:36 PM
Transmission noise yj jordan TJ Wrangler Technical Forum 2 12-17-2008 11:16 PM
Odd noise from transmission cajun_jeep YJ Wrangler Technical Forum 4 07-05-2008 06:15 PM
Transmission Noise?? jeepfury YJ Wrangler Technical Forum 3 08-29-2005 11:02 PM
