Transmission Noise - JeepForum.com
post #1 of 3 Old 02-08-2012, 06:57 AM Thread Starter
packersxxxi
Transmission Noise
ok i have a tj from 2000. About a year ago i swamped my wrangler and needed to get a new transmission. I had no issues until about 2 weeks ago. I decided to take my wrangler down a trail and went through some shallow water (about midway up the tires) and hit a few big bumps. Ever since then it has been making a squeaking noise at any speed above 25mph but it seems to stop after i take it on the highway. There have been no performance issues, but i am worried that something could happen. Any help would be appreciated thanks
packersxxxi is offline
post #2 of 3 Old 02-08-2012, 10:14 AM
JWebber
Check your front drive shaft CV joint ( UP BY THE T-CASE) you could be having the angry sparrows. A quick way to check it is to remove the front DS off of the front pinion axle yoke and bungee it on to the frame. Make sure it's secure well and DO NOT put it into 4wd mode at all. Then drive it and see if the noise is gone. If it's not I would drain the fluid out of tranny and see if you have water intrusion in it. Is this a manuel or auto tranny???
JWebber is offline
post #3 of 3 Old 02-15-2012, 08:43 PM Thread Starter
packersxxxi
Its an auto trans... got new tires put on today and i had the people at the place check it out to see if anything was wrong and they said it looked fine, but its still making the noise!
noise , tj , transmission
Transmission Noise? Gobbles347 TJ Wrangler Technical Forum 4 08-22-2011 02:25 PM
92 YJ transmission noise deeincitti YJ Wrangler Technical Forum 26 11-04-2009 06:03 AM
Transmission Noise bail315 TJ Wrangler Technical Forum 0 03-04-2008 07:49 PM
Transmission noise? MichaelJames TJ Wrangler Technical Forum 3 10-22-2004 06:16 AM
Transmission noise katiedog YJ Wrangler Technical Forum 2 06-15-2002 07:08 AM
