Transmission Noise? - JeepForum.com
post #1 of 5 Old 08-22-2011, 01:46 PM Thread Starter
Gobbles347
Transmission Noise?
I have a 01 sport so i think that is the NV3550 transmission? Anyway did some offroading over the weekend, and about an hour into the trip home in the highway I noticed a horrible noise, when I would let off the gas pedal it would go away then come back as soon as I pressed the gas again. It doesnt make the sound in reverse but does in 1-5 gears. any ideas?
Thanks in advance
Firefighters Jeep Club
Yellow Jeep Club
Michigan Jeepers Club #26
Gobbles347 is offline
post #2 of 5 Old 08-22-2011, 01:58 PM
JWebber
Could be pinion bearings, ujoints and or your tranny. You will be surprised when pinion bearings go, how much they transfer sound threw the tranny and t-case. Time to crawl under the jeep and inspect!
JWebber is offline
post #3 of 5 Old 08-22-2011, 02:09 PM Thread Starter
Gobbles347
Well the sound is alot faster than if it was a driveshaft/ujoint issue and the fact that it doesnt happen in reverse but in forward gears makes me believe trans?
Yellow Jeep Club
post #4 of 5 Old 08-22-2011, 02:16 PM
JWebber
Well how many miles on the fluid in there? and whats the level? Start there!
JWebber is offline
post #5 of 5 Old 08-22-2011, 02:25 PM Thread Starter
Gobbles347
I had the clutch replaced almost 30,000 miles ago, and ya i should prolly drain the fluid and fill it back up and see if that helps
Yellow Jeep Club
Transmission noise? jds79cj TJ Wrangler Technical Forum 1 02-25-2011 02:56 PM
Transmission Noise 02jeepwrangler TJ Wrangler Technical Forum 5 10-14-2010 09:17 PM
transmission noise godzirra YJ Wrangler Technical Forum 3 07-10-2010 10:12 PM
Odd noise from transmission cajun_jeep YJ Wrangler Technical Forum 4 07-05-2008 06:15 PM
Transmission noise? MichaelJames TJ Wrangler Technical Forum 3 10-22-2004 06:16 AM
