Is the Transmission mount on the TJ's 00-04 NV3500 centered between the frame rails?
#1 | |
Some Call me RockDog
I am needing to know this because i'm trying to center my custom skid. I should have taken measurements before I dropped the factory but I didn't. If no one knows for 100% sure, I will have to put it all back together just to see. Please help... thanks. Have a great day.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#2 | |
i forgot to mark mine as well. there is a lot of variation in these TJ frames and mounts and what is centered on one might not be on another. i put mine together many times and it is still easier than cutting and redoing a hasty weld. sorry I know that isnt what you want to hear....
[COLOR=Navy][SIZE=2]03 Patriot Blue Sport[/SIZE][/COLOR] Rubi d44 both ends, Crane Diff Covers, Rock trac t-case Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers knoblock rear bumper, OBA in process, bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax Currie HD steering Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt HEMI & 5spd Auto |
#3 |
When I installed my 33 Engineering skid on my 04 with the NV3550 I made an observation that the transmission mounting point is NOT centered between the frame. I don't remember which direction off center it was?
#4 |
I'm not 100%, but would it make sense that it would be off center the same way the engine is? I know the crankshaft is off center I think to the Pass side.
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco brakes, Raptor liner 10 Dodge Journey AWD 02 TJ salvage father and son build 98 XJ Classic Stock 91 Schoolbus converted to an rv for goin to Nascar races Former owner of CJ's, XJ's, a ZJ and a FSJ Cherokee. |
#5 |
it's not centered. I ended up putting the factory skid back on to get the mounting points. Then I jacked it up again. I jacked from the back of the mount so it didn't move to one side while jacking it up.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
