Is the Transmission mount on the TJ's 00-04 NV3500 centered between the frame rails? - JeepForum.com
post #1 of 5 Old 04-15-2007, 05:19 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I am needing to know this because i'm trying to center my custom skid. I should have taken measurements before I dropped the factory but I didn't. If no one knows for 100% sure, I will have to put it all back together just to see. Please help... thanks. Have a great day.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 5 Old 04-15-2007, 05:50 PM
cincytj
cincytj's Avatar
i forgot to mark mine as well. there is a lot of variation in these TJ frames and mounts and what is centered on one might not be on another. i put mine together many times and it is still easier than cutting and redoing a hasty weld. sorry I know that isnt what you want to hear....
03 Patriot Blue Sport
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
cincytj is offline
post #3 of 5 Old 04-15-2007, 06:01 PM
cyclerider105
cyclerider105's Avatar
When I installed my 33 Engineering skid on my 04 with the NV3550 I made an observation that the transmission mounting point is NOT centered between the frame. I don't remember which direction off center it was?
cyclerider105 is offline
post #4 of 5 Old 04-15-2007, 06:49 PM
dodgetk81
I'm not 100%, but would it make sense that it would be off center the same way the engine is? I know the crankshaft is off center I think to the Pass side.
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco
dodgetk81 is offline
post #5 of 5 Old 04-15-2007, 10:28 PM Thread Starter
JeepRocks86
it's not centered. I ended up putting the factory skid back on to get the mounting points. Then I jacked it up again. I jacked from the back of the mount so it didn't move to one side while jacking it up.
For Sale:
Rusted Out Frame Rails Hemi2Jeep YJ Wrangler Technical Forum 16 07-18-2009 12:53 PM
New Transmission (NV3500) Time? tsielski TJ Wrangler Technical Forum 0 09-22-2008 02:43 PM
Off-centered winch mount? smcurry83 TJ Wrangler Technical Forum 6 08-25-2008 04:56 PM
Rock rails/sliders...which is better? Frame Mount or Body Mount Sparty TJ Wrangler Technical Forum 33 08-22-2005 07:58 PM
How to mount lights centered on stock bumper??? BaaBaa TJ Wrangler Technical Forum 14 07-24-2004 10:50 PM
