Transmission linkage issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Transmission linkage issues
Rough Country Jeep Suspension Deals at Rockridge 4WD!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO The ULTIMATE "Selectable" Locker System! Brough
Unread 03-16-2014, 11:03 AM   #1
jeepinmax23
Junior Member
Hey everyone, I'm thinking about installing a 4 inch ProComp suspension lift and I was wondering if anyone had problems with the transmission linkage after installing a lift, and if you do what linkage extension did you get? thanks.
jeepinmax23 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2014, 11:06 AM   #2
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
You might want to re-think that lift.A MML will fix the linkage angle.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is offline   Reply With Quote Quick reply to this message
