Transmission issue - JeepForum.com
post #1 of 5 Old 07-25-2010, 11:32 AM Thread Starter
thatnameisinuse
Transmission issue
Hello Guys
About two thousand miles ago I had my trans flushed (32rh) since that time a few things have happened
1. A fluid leak I cannot find , looks like it coming from the driver side where the cooler lines attach. I even removed my front drive shaft for a better view, and btw the dipstick reads that the level is normal
2. The jeep will not move either forward or reverse until the engine has run for about 20 seconds.
3. Today while driving a very short distance it struggled to maintain 50 mph and developed a burning smell. I returned home let it idle for a few minutes and checked the fluid which looked normal color and normal level.
I am kinda stumped here and ideas as to what the issue may be , I appreciate any ideas.
Thanks Pat
thatnameisinuse is offline
post #2 of 5 Old 07-25-2010, 11:44 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Did the filter get changed with the fluid?...
Knuckelhead is offline
post #3 of 5 Old 07-25-2010, 11:53 AM Thread Starter
thatnameisinuse
no
post #4 of 5 Old 07-25-2010, 12:05 PM
JerseyDoug
Can I go home now?
Hope you're wrong about that. I see where you are going, I think. I just changed mine myself, but was unable to remove the filter, so couldn't change it. It did not appear clogged and the old fluid did not appear very dirty. I'll have to keep an eye on mine.
I didn't think about a clogged filter preventing the AT fluid from the pan from circulating through the AT.
To the OP, I'd have that checked asap.
JerseyDoug is offline
post #5 of 5 Old 07-25-2010, 12:27 PM
Knuckelhead
AFSOC Retired
Originally Posted by thatnameisinuse View Post
no
Time to drop the pan...
transmission , 32rh , leak
Transmission issue zfender14 YJ Wrangler Technical Forum 2 10-22-2009 10:40 PM
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 05:07 PM
Help with transmission issue BtownFord YJ Wrangler Technical Forum 12 05-04-2009 08:50 AM
Transmission Issue--Please Help!! hondurena YJ Wrangler Technical Forum 2 12-25-2008 01:30 PM
Transmission Issue? doubleup TJ Wrangler Technical Forum 14 12-19-2008 06:57 AM
