Transmission Fluid Change - JeepForum.com
post #1 of 14 Old 11-28-2006, 04:30 PM Thread Starter
Skeezer
I need to change the transmission fluid in my 06 TJ 4.0L, auto. Is there an easier way than dropping the pan ? Any suggestions would be appreciated, Thanks.
2005 Rubicon
Skeezer is offline
post #2 of 14 Old 11-28-2006, 04:32 PM
SecondTJ
SecondTJ's Avatar
Not really. Some people tap the pan and put in a drain plug for it.
Even so, your not going to get all the fluid out. The best thing to do is a complete trans flush, thats the only way to get all the fluid out of the lines, torque converter, etc.
How many miles are on your 06 that you're looking at changing the trans fluid already? Its service interval is every 30k
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 14 Old 11-28-2006, 04:33 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
Not really. If there's a drain plug on the bottom of the pan (not terribly likely), it might save some of the mess.
But the pan should come off anyhow so you can change the filter.
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #4 of 14 Old 11-28-2006, 05:04 PM Thread Starter
Skeezer
I have 18,000 miles on it, but I think I have some water in it. Would water show up on the dipstick ? I was buried in about 4' of water Saturday for a few minutes before I got pulled out. While on my way home I noticed a noise comming from the tranny, sounds like a vacuum running.
But no water shows up on the dipstick
2005 Rubicon
Skeezer is offline
post #5 of 14 Old 11-28-2006, 05:15 PM
SpaceWrangler
Gnarly Adventurer
Is the fluid still red and clear? Or is it milky now? If it's milky, there's water in it.
Even if the fluid still looks okay, a fluid / filter change is cheap insurance, compared to an auto trans rebuild.
Be sure to flush the old fluid out of the converter also.
post #6 of 14 Old 11-28-2006, 05:18 PM Thread Starter
Skeezer
No, it's not milky. It looks normal to me, but i'm just worried about the strange noise. I changed my differential fluid this weekend and they had alot of water.
2005 Rubicon
Skeezer is offline
post #7 of 14 Old 11-28-2006, 05:23 PM
SpaceWrangler
Gnarly Adventurer
Here's a link to a How-To for flushing your converter...
http://www.jeepforum.com/forum/f9/trans-slipping-343345/
Scroll down to the second-to-the-last post.
post #8 of 14 Old 11-28-2006, 05:25 PM Thread Starter
Skeezer
Great, thank you.
2005 Rubicon
Skeezer is offline
post #9 of 14 Old 11-28-2006, 05:30 PM
JBTJ
You can disconnect the supply line that runs from the tranny to the radiator. Add another piece of rubber line at that point and insert it into a milk jug that you mark off in a three quart line. Have a friend start the jeep and keep a foot on the brake and place into netural. THe tranny pump will begin to pump fluid out of the torque converter. When the milk jug fills up to the 3 quart line turn off the motor. Pour the old fluid into a proper container for disposal and refill your tranny thru the dipstick tube the 3 quarts you pumped out. Repete this process untill fresh clean ATF fluid comes out. Should take about 12 to 15 quarts. But, be sure to change the trans filter and top off with fluid BEFORE you do this process.
JBTJ is offline
post #10 of 14 Old 11-28-2006, 05:44 PM
SpaceWrangler
Gnarly Adventurer
LOL!
JBTJ, it's your own write-up that I linked to!
Reruns, anyone?
post #11 of 14 Old 11-28-2006, 05:47 PM Thread Starter
Skeezer
Does anyone know roughly what a dealer charges for a tranny fluid change ?
2005 Rubicon
Skeezer is offline
post #12 of 14 Old 11-28-2006, 05:57 PM
James04TJ
James04TJ's Avatar
IIRC, most dealers charge around $150-200. Most quick lubes charge around $100. Either way, you will want to use a shop that has a T-Tech as it offers the best change.
As for fluids, if you do it yourself (or have anyone else do it), make sure that you use a fluid meeting Chrysler's ATF+4 spec. Amsoil, Redline, and IIRC Valvoline all make fluids meeting the ATF+4 spec. I have seen MOPAR fluid run around $15/qt.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #13 of 14 Old 11-28-2006, 05:59 PM
JBTJ
Originally Posted by Stretch67
LOL!
Reruns, anyone?
Yeah, that is pretty funny isnít it
JBTJ is offline
post #14 of 14 Old 11-28-2006, 06:04 PM
JBTJ
To add to this. A flush is okay to do if the fluid has been changed frequently in the transmission. If not, then flushing will move some of the build up crud to all the wrong places. Thus resulting in poor transmission performance. Since your Jeep has very low mileage you wonít have to worry about that problem. Though you can buy the Valvoline ATF+4 for just under 5 bucks a quart. Still much cheaper to do your self.
JBTJ is offline
Transmission Fluid Change EricYoung YJ Wrangler Technical Forum 5 04-03-2010 04:34 AM
99 Transmission fluid change... ((~JEEP~)) TJ Wrangler Technical Forum 0 08-13-2006 09:49 PM
transmission fluid change?? UTmike TJ Wrangler Technical Forum 2 05-27-2006 02:22 PM
Transmission Fluid Change JungleLarry YJ Wrangler Technical Forum 15 03-11-2005 09:26 AM
Should I change my Transmission Fluid Dctjwrangler01 TJ Wrangler Technical Forum 1 06-19-2004 05:56 PM
