transmission fluid change?? - JeepForum.com
post #1 of 3 Old 05-27-2006, 02:50 PM Thread Starter
UTmike
UTmike's Avatar
I'm trying to get my fluids changed out today and i'm not sure if these two things are the drain and fill holes for my transmission fluid. i don't have any tools that fit in these either.
4.5" RE Long Arm, 37" Mud Grapplers on Beadlocks, OX Locked Dana 60s front and rear
UTmike is offline
post #2 of 3 Old 05-27-2006, 03:10 PM
TJ on the Rocks
TJ on the Rocks's Avatar
Yes sir , they are the correct plugs . You'll need a 17mm allen wrench for those
Remove the fill plug first , then proceed to the drain plug
Filling it back up can get messy since the hole is tough to get at with a typical bottle .
A bottle pump comes in handy
Here's what I use to re-fill it . Draw the fluid from the bottle , then push it into the tranny . Repeat 'till full or ~ at 2.41 qts.
TJ on the Rocks is offline
post #3 of 3 Old 05-27-2006, 03:22 PM Thread Starter
UTmike
UTmike's Avatar
awesome, thankyou
UTmike is offline
Transmission Fluid Change EricYoung YJ Wrangler Technical Forum 5 04-03-2010 05:34 AM
Transmission Fluid Change Skeezer TJ Wrangler Technical Forum 13 11-28-2006 07:04 PM
99 Transmission fluid change... ((~JEEP~)) TJ Wrangler Technical Forum 0 08-13-2006 10:49 PM
Transmission Fluid Change JungleLarry YJ Wrangler Technical Forum 15 03-11-2005 10:26 AM
Should I change my Transmission Fluid Dctjwrangler01 TJ Wrangler Technical Forum 1 06-19-2004 06:56 PM
