Transmission Drain Plug - NONE!! - JeepForum.com
post #1 of 30 Old 07-18-2011, 08:40 AM Thread Starter
TIMETOPLAY
WTF, no drain plug. Maybe I'm missing something, is it located somewhere else?
1997 Jeep Wrangler Sport (4cyl, 2.5) Automatic
TIMETOPLAY is offline
post #2 of 30 Old 07-18-2011, 08:42 AM
Necko2529
Necko2529's Avatar
If there's a hole In your transmission then you're missing a drain plug.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #3 of 30 Old 07-18-2011, 08:44 AM
JBTJ
Auto's don't have drain plugs, unless you make one or buy a pan that has one built in. You need to drop the pan to get the fluid out.
JBTJ is offline
post #4 of 30 Old 07-18-2011, 08:49 AM
Necko2529
Necko2529's Avatar
Dang it. Fill your profile so I don't make my self look like a fool.
post #5 of 30 Old 07-18-2011, 08:50 AM Thread Starter
TIMETOPLAY
Damn, if that's not some poor engineering I don't know what is.
post #6 of 30 Old 07-18-2011, 09:30 AM
j_niko
2009 JK Wrangler
if I remember right, that's pretty common.
2000 - Sahara
1997 - Sahara
j_niko is offline
post #7 of 30 Old 07-18-2011, 09:33 AM
Imped
Imped's Avatar
Very common. Nothing to do with poor engineering.
OlllllllO
IndyORV
Imped is offline
post #8 of 30 Old 07-18-2011, 09:42 AM
IslandTJ
The Mopar deep pan has a plug .
http://www.4x4groupbuy.com/store/dee...on-p-3369.html
Now Jeeping in Oregon
IslandTJ is offline
post #9 of 30 Old 07-18-2011, 09:47 AM
JBTJ
For the 30RH?
JBTJ is offline
post #10 of 30 Old 07-18-2011, 09:56 AM
IslandTJ
For the 30RH?
Sorry, for the 32RH or TF999.
IslandTJ is offline
post #11 of 30 Old 07-18-2011, 10:08 AM
JBTJ
Yep, the OP has a 30RH. Be nice if they did though.
JBTJ is offline
post #12 of 30 Old 07-18-2011, 10:10 AM Thread Starter
TIMETOPLAY
IMO it does.
post #13 of 30 Old 07-18-2011, 10:51 AM
LJameson
Originally Posted by TIMETOPLAY View Post
IMO it does.
Well you have a ignorant opinion.
Probably 90% of autos from all manufacturers don't have drain plugs. Some of them are sealed units and don't provide any means of draining or filling the trans with fluid unless you have a special tool.
1990 YJ
LJameson is offline
post #14 of 30 Old 07-18-2011, 11:49 AM
Kadmost
It's done for two reasons, the main one is so you will have to drop the pan, which means you will need a new gasket, gaskets come with the filter, and that's what they want you to do...change the filter. And while you are in there you will likely wipe off the magnet
The cars with drain plugs typically have a wire mesh filter rather than a paper or fiber one.
The second reason is because shade tree mechanics and occasionally dealers service would accidentally drain the transmission and then add more engine oil to the crankcase.
My father did this to his Volvo a couple decades back, I believe it was the last time he ever worked on a car
Kadmost is offline
post #15 of 30 Old 07-18-2011, 12:15 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
There are some folks on here who shall remain nameless that have drained the wrong one and overfilled the other on other vehicles.
Let's just say their SO was not a happy camper when the dealership pointed out the error after the car was towed in for repair.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
Manual transmission drain plug..? fishmanwill YJ Wrangler Technical Forum 8 01-14-2013 10:15 AM
Transmission pan sensor/drain plug? Dronac JK Wrangler Technical Forum 9 11-03-2010 05:52 PM
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 03:26 AM
transmission drain plug?? 99dime YJ Wrangler Technical Forum 5 12-02-2006 11:42 AM
87 wrangler transmission drain plug ? DaSham58 YJ Wrangler Technical Forum 5 03-11-2006 07:19 AM
