Transmission does it need to be rebuilt? - JeepForum.com
post #1 of 1 Old 06-23-2009, 09:13 PM Thread Starter
melcrim
I have a 99 TJ with AX-5 transmission with 163,000 miles. I'm in the process of dropping the transmission to replace the clutch. The throwout bearing was shrieking. Prior to this it has been getting harder to shift into 1st & reverse. I need to push down really hard on the shifter & sometimes to get into reverse I have to shift into 1st then quickly into reverse.
My friend says that while I have the tranny out I might as well get a rebuild kit and rebuild the transmission. UGH!! What do you guys think? I really don't want to attempt that at this point. I don't want to spend the $$$ plus I know it will take me 5x longer to rebuild the transmission then it should. My friend is a mechanic so he knows what he's doing. I'm learning each step of the way. I manage to get the work done but it's a struggle. If this doesn't need to be done I'd rather leave it alone. I'm concerned it could be a big can of worms. There are no leaks and I don't hear any grinding.
On the other hand if it has to be done then it has to be done. I don't know if my hard shifting issues are because the parts in the trans are wearing out or because of the bad throwout bearing.
What are your thoughts?
melcrim is offline
My New Rebuilt Transmission bunkrdfool YJ Wrangler Technical Forum 13 09-18-2008 05:46 AM
AX5 Transmission New not rebuilt Canfourjeep YJ Wrangler Technical Forum 4 01-08-2008 08:00 PM
Getting my transmission rebuilt Barroom Hero TJ Wrangler Technical Forum 11 03-24-2006 09:54 AM
Please help me rebuilt an AX5 transmission wittymonkey YJ Wrangler Technical Forum 3 07-23-2004 07:39 PM
Rebuilt transmission concerns damonejeep YJ Wrangler Technical Forum 5 02-15-2002 10:18 AM
