Quantcast Transmission Cooler - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Transmission Cooler
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 02-19-2010, 11:18 PM   #1
waldoo
Transmission Cooler
I drive in a very hot area (desert) with my Auto trans TJ. I hear some people recomending to install a Transmission Cooler like this one :
Pacer Performance Products 20561 - Derale Direct Fit Transmission Cooler for 87-06 Jeep® Wrangler YJ, TJ & Unlimited with Automatic Transmission - Quadratec
Tried to search on this forum but not too many details. Anyone used tis is it good?? what is the best way to keep a trans from heating.
Thanks,
waldoo is offline   Reply With Quote
Old 02-19-2010, 11:24 PM   #2
MisfitSeven
MAIL Crawler.
MisfitSeven's Avatar
that kit is nice. i just bought a kit from o'reilly's for $50. its just a little radiator that zip ties in front of the real radiator. with that one from quadratec, you can put it wherever you want. save your money, i would check your local auto parts store for a universal kit before i bought that one.
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1.
*85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces.
Originally Posted by Patton View Post
You won the nicest mail jeep award.
I'm typing this real slow to try and help you.
NEW and USED parts for sale. PM me.
MisfitSeven is offline   Reply With Quote
Old 02-20-2010, 12:38 AM   #3
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
I picked up one of these on Amazon for about $65.00 shipped...
Automatic Transmission SuperCooler rated at 13,000 BTU 11"x7-1/2"x3/4"
"Two things are infinite... the Universe and human stupidity. And I'm not sure about the Universe."
-Albert Einstein
SpaceWrangler is offline   Reply With Quote
Old 02-20-2010, 12:56 AM   #4
waldoo
Is it a good upgrade for the tranny?
how are u guys liking it?
Old 02-20-2010, 01:04 AM   #5
SpaceWrangler
Gnarly Adventurer
I use the Jeep to tow my bass boat, so the cooler is a definite plus there. Also, it keeps the trans a lot cooler when wheeling up in the mountains, or even just climbing around in the woods. I believe a cooler would also be a good idea if you wheeled in sand.
I got the Mopar deep trans pan as well. It adds another quart of fluid to the system, and prevents the trans pump pick-up from starving for fluid when wheeling at steep angles. It also has a drain plug to make fluid changes easier.
Get a temperature gauge also, so you can stay abreast of conditions down in your slushbox.
-Albert Einstein
Old 02-20-2010, 01:11 AM   #6
waldoo
Thats great, any prefference on the brands for the cooler and trans pan? and where u got them from.
cheers
Old 02-20-2010, 08:48 AM   #7
SpaceWrangler
Gnarly Adventurer
The deep pan is a Mopar part, so it's available at any Chrysler / Jeep dealer. The part number is P4007886AB. It is available from various other parts sources, though. I got mine from Summit Racing...
Mopar Performance P4007886AB - Mopar Performance Extra Capacity Steel Transmission Oil Pans - Overview - SummitRacing.com
There's no preference on the brand of cooler, really. I went with B&M because they specialize in automatic transmissions for hot-rods, and I have a bit of experience with their stuff. As mentioned earlier, I found it on Amazon for about $65 shipped...
Clicky: http://www.amazon.com/70268-SuperCooler-Automatic-Transmission-Cooler/dp/B000CIGE9G
Tru-Cool is another brand I've used, but I'm not sure of the specific applications anymore. Years ago, I put one on my F-350, and it's been great.
I run this same temperature gauge on both the Jeep and the truck....
TCI 801000 TCI Transmission Temperature Gauges
I have the sensor plumbed into the external cooling line coming out of the transmission so I can have a better sense of how hard the trans is working. Putting the gauge sensor in the pan or in the return line will tell you the temperature of the ATF after it has run through the coolers... not a very accurate way of keeping up with the trans' internal temps.
-Albert Einstein
Old 02-20-2010, 01:55 PM   #8
Knuckelhead
Knuckelhead's Avatar
B&M has a fan cooler;
Adding a filter helps also...
Originally Posted by Yucca-man View Post
My experience is that poly loves to groan
Knuckelhead is offline   Reply With Quote
Old 03-02-2010, 02:46 PM   #9
fireman535
Just bought the B&M 70268 Tranny cooler from amazon for $46 with free shipping. Hopefully the install will go alright. Hey Stretch, the Mopar deep pan P4007886AB, is that a direct fit for the 2001 Wrangler Sport?
fireman535 is offline   Reply With Quote
Old 03-02-2010, 11:44 PM   #10
waldoo
Let us know how it goes with the instalation. Where did u put it & did u need any other hardware than what is in the kit...
Will the deep pan fit on the 2006 sport???
Old 03-03-2010, 12:59 AM   #11
cvd
cvd's Avatar
I've read many times that the 4 speed auto in the 03 - 06 TJ doesn't need the deep pan. I'm guessing the OEM pan on that transmission is fairly deep.
cvd is offline   Reply With Quote
Old 03-03-2010, 01:05 AM   #12
waldoo
Great!! So the cooler should be enough...
Is it a hard install or fairly easy??
Old 03-03-2010, 06:40 AM   #13
SpaceWrangler
Gnarly Adventurer
If you're running the 30RH (4 cylinder) or 32 RH (6 cylinder) 3-speed automatic, yep.
-Albert Einstein
Glock Forum
