Transfercase broke - JeepForum.com
post #1 of 42 Old 01-13-2013, 05:36 PM Thread Starter
RedHotChiliDog
Transfercase broke
Ill have pics tomm afternoon but I just put on a 1inch body lift to add to my 2.5 inches suspension lift. Going down the highway I hear a bang and my driveshaft and transfer case basically blew up. Where can I get a new transfer case and for how much? I can only find places that sells parts to it...
RedHotChiliDog is offline
post #2 of 42 Old 01-13-2013, 05:42 PM
EGLESCT
I'd check craigslist. I just saw one on there going for $150.
"Courage is being scared to death... and saddling up anyway" - John Wayne
EGLESCT is offline
post #3 of 42 Old 01-13-2013, 05:42 PM Thread Starter
RedHotChiliDog
What kind of transfer case should I get too? Stock or something better?
post #4 of 42 Old 01-13-2013, 05:42 PM
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
Crap, wish I saw this earlier. I just had an Atlas installed and gave my NP231 with SYE to my buddy. Had I known someone needed it, I would have sent it to ya for the cost of shipping. Sorry bro
VA3IPB
The only True Professional Mechanic in the Greater Toronto Area for Modified Jeeps, and trucks. If Rock Spyder hasn't seen it before, or done it before, you don't need it.
TheHeretic is offline
post #5 of 42 Old 01-13-2013, 05:45 PM
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
Atlas, and never worry about a transfer case again. Stay away from the NP241. It's not a bad transfer case, but for the price, unless someone is giving you one, the Atlas is worlds (pun intended) better then the New Process transfer cases. IMHO
VA3IPB
post #6 of 42 Old 01-13-2013, 05:46 PM
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
$150 for an NP231 is a fair Price. Certainly cheaper then an Atlas too.
VA3IPB
post #7 of 42 Old 01-13-2013, 05:49 PM
CloakedLJ
Out of curiosity did the t-case break at the front driveshaft? Did it take out any fuel lines or electrical?
If you have the money this is a very good option.
http://www.advanceadapters.com/produ...-applications/
Or if you want a new stock install replacement you could try one of these.
http://www.jbconversions.com/product...ete_stdsye.php
if you want to upgrade to the Rubicon T-case
http://www.jbconversions.com/products/nvg241or/
If your looking for a used T-case try these guys or posting an ad in the wanted section on here.
http://daveysjeeps.com/specials.html
Also depending on how damaged the case halves are JB conversions sells most if not all of the parts to rebuild it
hope this helps.
CloakedLJ is offline
post #8 of 42 Old 01-13-2013, 05:55 PM Thread Starter
RedHotChiliDog
I want cheap as possible but i want something that isn't going to **** again either...ill do some homework tonight and like i said ill post pics tomm. Are these things easy to replace or should I pay a real mechanic?
post #9 of 42 Old 01-13-2013, 05:58 PM
rchase559
I saw someone already ask but I'll mention it again. Where did the case break? Did the centering ball on the front driveshaft seize and crack the case in two? If so this was a problem with the driveshaft rather than the t-case
rchase559 is offline
post #10 of 42 Old 01-13-2013, 06:02 PM
EGLESCT
If you are slightly mechanically inclined, they are a piece of cake. It's just heavy, bulky, and awkward. But easy.
Jack the transmission up slightly and get it supported,
Unbolt and remove the transfer case skid plate
Disconnect linkages/electrical connections
Disconnect driveshafts
Drain oil from transfer case
Support transfer case with jack, unbolt transfercase from transmission and lower.
Reverse steps for installation.
EGLESCT is offline
post #11 of 42 Old 01-13-2013, 06:13 PM Thread Starter
RedHotChiliDog
So that's pics of said incident...man this really sucks
post #12 of 42 Old 01-13-2013, 09:36 PM Thread Starter
RedHotChiliDog
Do you guys recommend any strong somewhat cheap rear driveshafts I can get for the jeep as well? I'm gonna do the official measuring tomm but I figure if you guys basically already know the specs I could get good recommendations
post #13 of 42 Old 01-13-2013, 10:15 PM
Kodiak17
Tatton and Tom Woods make driveshafts stronger than OEM, only you can determine if they're cheap enough. You didn't supply a budget. I would just replace your t-case with another NP231. They're cheap, strong, and very reliable. An atlas is great, but unless you make a **** ton of money, I wouldn't call them or the swap cheap/easy.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #14 of 42 Old 01-14-2013, 07:40 AM
yachtjockey
Ive got a 231 and rear D/S in West palm Beach for $250. They are out of a 99 with 50,000 miles. Im about 3 1/2 hours South of you.
yachtjockey is offline
post #15 of 42 Old 01-14-2013, 08:51 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
There is nothing wrong with a stock one if you stay on top of your maintenance, don't drive it with the pinion angle screwed up so that it has vibes, and check it once in awhile to make sure the bolts that hold the u-joint in are good.
How many of those did you miss?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
