transfer case skid plate - JeepForum.com
post #1 of 8 Old 04-12-2005, 06:47 AM Thread Starter
86comanche
I would like to upgrade my transfer case skid plate. I have a 04 TJ SE with the RE BB 2" lift. I would like to get a little more clearance under the jeep. Which skid plate works the best and has the least amount of problems. I dont want to have to get the sye and new drive shaft just because i got a better skid plate. I am looking for one that is a little higher off the ground and has a nice flat surface. Any help would be great!
R.I.P 2004 TJ SE
86comanche is offline
post #2 of 8 Old 04-12-2005, 08:02 AM
Jeepin' Rock Cl
You're probably going to need SYE with just about any flat skid as it raises your transfer case so much.
Jeepin' Rock Cl is offline
post #3 of 8 Old 04-12-2005, 08:43 AM
igofshn
Locked @ both ends
igofshn's Avatar
That is correct. A flat skid will require a sye/cv drive shaft.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 8 Old 04-12-2005, 08:58 AM Thread Starter
86comanche
skid plate
Im not trying to go completly flat, id like soomething better than stock...is there a mod to the stock plate to make things better...i keep getting cught on all the ridges on the stock plate
R.I.P 2004 TJ SE
post #5 of 8 Old 04-12-2005, 09:30 AM
2KJ33PTJ
1981 CJ7
SYE is required for any/all skids I've ever seen (but, do post up if you find one that does not require an SYE).
You'll also have to do a BL and MML (body and motormount lifts) since you'll be raising the t-case.
As for which one...I'm looking at one by http://www.goferitoffroad.com/products.htm. Very simple design (K.I.S.S.) and reasonably priced.
2KJ33PTJ is offline
post #6 of 8 Old 04-12-2005, 10:02 AM Thread Starter
86comanche
skid
What if i were to get a 3/16" thick plat and weld it to the stock plat to "smooth" it out
R.I.P 2004 TJ SE
post #7 of 8 Old 04-12-2005, 10:29 AM
BNovak
BNovak's Avatar
Get one of the engine / oil pan skids. They bolt to the lower front part of the tranny pan to help keep it from "Shoveling" when you go over stuff. This way you won't need an SYE.
If you do go this route, weld some strip steel onto it before you install it to make the plate a little beefier. I've ben the heck out of my warn skid.
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #8 of 8 Old 04-12-2005, 10:31 AM
diveguy
Jeep Medic Fabrication makes one that covers your oil pan and tranny, and bolts onto your existing stock plate for your transfer case. This way it is like you have one continuous skid plate going from your oil pan to your t-case. He makes it from 1/4" steel and if you have a lift, he modifies it for you.
2008 Blue Sahara Unlimited
275/70R18 (33.2 x 10.5) BFG AT/KO
diveguy is offline
Transfer Case Skid Plate Billyjon1 TJ Wrangler Technical Forum 1 02-11-2009 04:01 PM
New Transfer Case Skid Plate?? Jeep Man 10 YJ Wrangler Technical Forum 30 04-18-2008 10:03 AM
Skid Plate over transfer case RubiconsR4Grls2 TJ Wrangler Technical Forum 9 11-13-2007 12:22 PM
Transfer Case Skid Plate ntxjetta YJ Wrangler Technical Forum 6 02-13-2007 06:56 PM
Help can't get transfer case skid plate off patphish TJ Wrangler Technical Forum 20 10-16-2006 07:15 PM
