Transfer case skid bolts? - JeepForum.com
post #1 of 8 Old 01-25-2007, 01:02 PM Thread Starter
blacktjsport
Are the bolts holding the transfer case skid plate to the frame the same size on all TJ's and LJ's?? I know companys make different skids for 97-02 and 03-06, but are the actual bolts the same size (thread pitch and bolt diameter) just in a slightly different location?? Thanks,
--Matt
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline
post #2 of 8 Old 01-25-2007, 01:20 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
http://www.jeepforum.com/forum/f9/what-size-thread-03-tc-bolts-347018/
asked it a while back
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #3 of 8 Old 01-25-2007, 01:53 PM
SecondTJ
SecondTJ's Avatar
97-02 were 1/2"
03-06 is 12mm
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #4 of 8 Old 01-25-2007, 02:03 PM
amp77
amp77's Avatar
If you're planning on removing them, do yourself a favor and tighten them a bit before you start loosening them. Trust me. Or... maybe you already figured that out and this is why you need some?
amp77 is offline
post #5 of 8 Old 01-25-2007, 11:53 PM Thread Starter
blacktjsport
I'm asking this because I will be removing my stock t-case bolts to install a RE t-case drop after I install my RE 3.5 to get me home b4 I can install my SYE. The t-case drop and bolts are from an '04 LJ via RE but I just wanna make sure they will fit my 2000. I dont wanna get to the install point and realize I need different bolts, that might kill me. Anyone positive the thread pitch are the same on all year TJ's 97-06? I realize the heads of the bolts might be different but are the thread pitches the same? Sorry for the rant and confusion.
-Matt
post #6 of 8 Old 01-26-2007, 06:48 AM
amp77
amp77's Avatar
Is there some reason that you think you won't be able to reuse the stock bolts?
Are we talking about the 6 bolts that hold the skid up? Or, the 4 small nuts that hold the tranny mount to the skid?
amp77 is offline
post #7 of 8 Old 01-26-2007, 10:35 AM
SecondTJ
SecondTJ's Avatar
Bolts for a '04 will not work on a '00
SecondTJ is offline
post #8 of 8 Old 01-26-2007, 04:02 PM
Whobeme
2010 JK Wrangler
97-02 are SAE and the 03-06 are metric. Sorry, I don't know the pitch or thread. I pulled one out and took it with me to the local hardware store.
Whobeme is offline
Transfer case skid bolts provinT13 YJ Wrangler Technical Forum 2 04-07-2009 01:29 PM
Transfer case skid bolts. 97ProjecTJ TJ Wrangler Technical Forum 4 07-20-2007 12:19 PM
Transfer case skid Bolts joedirt88 TJ Wrangler Technical Forum 9 06-04-2006 05:29 PM
transfer case skid plate bolts 86comanche TJ Wrangler Technical Forum 4 05-05-2005 08:15 AM
transfer case skid bolts??? scrappy TJ Wrangler Technical Forum 2 04-18-2005 04:09 PM
