Transfer Case Shifter Linkage - JeepForum.com
post #1 of 17 Old 04-14-2010, 11:34 AM Thread Starter
vindicated
Did you miss me?
vindicated's Avatar
Ok, so I was milling about the forum today and I came across a write-up that says a knocking noise (similar to mine) was cause by the t-case shifter linkage. I want to try this to see if it solves my problem but I believe this write-up is for an 01? Does anyone know if the part numbers supplied will fit my 06? Thanks! PS I tried to call the stealership and those nutballs hung up on me. Can I get these parts somewhere else?
the following below was taken from:
Jeep TJ Transfer Case Shifter Knocking TSB
What I found Out
I don't know who or why anyone would design a T-case shifter linkage as complicated as this or why it is mounted to the tub but this is where the knocking is coming from. What happens is that the bronze bushing/retainer holding the torque shaft wears out and/or the rubber gasket tears on the end. This allows the torque shaft to travel back and forth too much causing one of the links to tap on the bracket on the tub. This problem can also occur if you install a 1" body lift without installing the T-case shifter drop bracket supplied with many kits.
How to Fix It
If you are still under warranty, take the TSB (Technical Service Bulletin) number below to your dealer and have them deal with it. If you are over warranty, you can by the TSB kit from your dealer for about $19.
TSB 21-09-98 JUL 98
Transfer Case Shifter - Creaking/Thumping Noise
Part Numbers
05014148-AA Torque SH 21-105-001
Although the kit comes with new bushing for every link end, the only ones I needed was the bronze bushing/retainer and gasket. To install it, you will need to remove the body bracket from the tub. In order to do this, you will find the 4-bolts holding it in place underneath your driver side carpeting. The rest can be accessed from under your Jeep and you do not need to jack anything up or remove your T-case skid.
Originally Posted by bradthebard
Vin's so hard core, he drinks the whole jug of STFU and then has a three hour conversation about it.
vindicated is offline
post #2 of 17 Old 04-14-2010, 11:38 AM
biffgnar
biffgnar's Avatar
Look at some of the aftermarket replacements that get the bracket off the tub and, in some cases, replace the linkage. Check out AA or Teraflex or if your bank account is feeling good Novak.
Romney in 2020!
biffgnar is offline
post #3 of 17 Old 04-14-2010, 03:21 PM Thread Starter
vindicated
Did you miss me?
vindicated's Avatar
What do I look for? Cause this Mopar kit is supposedly just bushing and whatnot. Do I search for like, "t-case shifter linkage assembly" or something like that?
post #4 of 17 Old 04-14-2010, 03:32 PM
coreystj
Hello, im new to the forum, but have read for a while.
I opened a can of worms with my linkage, when i did a T-case drop. First i could not shift into 4low, then i did a drop bracket, and it would not shift past 4 hi, the linkage was hanging up on the bracket. I removed the drop bracket, put it back to stock, had full range of my shifter, but now the front axle wont engage. Installed the skyjacker linkage replacement bracket and have yet to be able to get the front axle to engage. I know my axle works, when i get under the jeep, i can have the case in low, and twist the front driveshaft and move the vehicle.
Sorry to distract your post, but i hope you do not have the same problems as I.
coreystj is offline
post #5 of 17 Old 04-14-2010, 03:42 PM Thread Starter
vindicated
Did you miss me?
vindicated's Avatar
^^ Thank you, but this is because of a clank clank clank noise I get when I push the clutch in. I heard it's because of these bad bushings and worn out brackets, so replacing them might fix this mystery noise. That's why I want to use facotry parts.
post #6 of 17 Old 04-14-2010, 03:49 PM
greenmachine99
greenmachine99's Avatar
You dont need to do anything fancy here. You need $20 worth of bushings to fix your problem. I just did this myself this weekend. All the brackets are the same and will work for your 06. I got mine at the dealer. I'm not sure where else to get them. It will come with 3 small bushings that you dont really need. All you need is the brass "bearing" type thing and the black boot that goes over the torque shaft.
greenmachine99 is offline
post #7 of 17 Old 04-14-2010, 03:50 PM Thread Starter
vindicated
Did you miss me?
vindicated's Avatar
cool, so is that part number I have on post 1 the correct info I need to give to the idiot dealer?
post #8 of 17 Old 04-14-2010, 03:56 PM
greenmachine99
Sure is. Its probably easier to tell them to look up TSB's and get it that way. Either way thats what you need.
post #9 of 17 Old 04-14-2010, 04:16 PM Thread Starter
vindicated
Did you miss me?
vindicated's Avatar
Thanks Green.
post #10 of 17 Old 04-14-2010, 06:04 PM
biffgnar
biffgnar's Avatar
Teraflex 4947100 - TeraFlex Transfer Case Shifter Linkage Adapter for 97-06 Jeep® Wrangler TJ & Unlimited - Quadratec
Advance Adapters 715542 - Advance Adapters Transfercase Shifter Bracket for 97-06 Jeep® Wrangler TJ - Quadratec
Novak's NP / NVG Shifter Assembly for Jeeps
These get the linkage off the tub and in most cases make it shift smoother.
Romney in 2020!
biffgnar is offline
post #11 of 17 Old 04-14-2010, 06:07 PM
biffgnar
biffgnar's Avatar
Sounds like you just need to adjust the length of the linkage. Can you get under there and manually shift the TC case? I have the Tera adapter and out of the box it wouldn't go into 4L but a little experimenting with the linkage length and nice and smooth now.
Romney in 2020!
biffgnar is offline
post #12 of 17 Old 04-23-2010, 09:37 AM
grisgris
Hey Vindi...How did it come out? I have the exact problem on my 2000 TJ , I figured out the source of the knock this week and was planning to stop by the dealership for the part this weekend.
grisgris is offline
post #13 of 17 Old 04-23-2010, 10:03 AM Thread Starter
vindicated
Did you miss me?
vindicated's Avatar
I dont have a problem getting it into gear, but I can try that.
Thank you!
I am going to the stealership tomorrow to buy this part and I will let you know how it worked.
post #14 of 17 Old 04-23-2010, 10:19 AM
biffgnar
biffgnar's Avatar
Note the quote in that post. Comment was directed at somebody else.
Romney in 2020!
biffgnar is offline
post #15 of 17 Old 04-23-2010, 10:21 AM Thread Starter
vindicated
Did you miss me?
vindicated's Avatar
Didnt even catch that. That was the guy who tried to hijack.
Thanks anyway!
transfer case shifter linkage gone bad province TJ Wrangler Technical Forum 1 01-27-2009 04:32 AM
Transfer case shifter linkage? cbr929rr TJ Wrangler Technical Forum 5 10-27-2005 04:53 PM
Transfer case shifter linkage adjustment? k8ysv TJ Wrangler Technical Forum 9 10-12-2005 06:39 PM
transfer Case Shifter linkage TSB JordyX TJ Wrangler Technical Forum 0 05-10-2005 07:05 PM
