Transfer Case Replacement? - JeepForum.com
post #1 of 10 Old 01-25-2013, 02:20 PM Thread Starter
RedHotChiliDog
I finally got a new np-231 because my old one got ****ed up to say the least. Anyways Im putting it in tomorrow and my friends who might help probably wont come to the shop till Im an hour or two in Im assuming. So any tips or anything like that? How exactly do you do it? I have a Chiltons I was just looking in and it says to remove the tranny as well but from what Ive heard I shouldnt have to do that...
RedHotChiliDog is offline
post #2 of 10 Old 01-25-2013, 02:23 PM
biffgnar
biffgnar's Avatar
No need to remove the transmission. Support the transmssion with a jackstand, remove skid, disconnect everything that connects to the TC (driveshafts, speedo cable, breather, shift linkage, etc.), remove bolts that hold TC to transmssion, remove TC (actually may be easier if you drain it first also). Reverse with new TC.
Romney in 2020!
biffgnar is online now
post #3 of 10 Old 01-25-2013, 02:36 PM Thread Starter
RedHotChiliDog
Theres a huge hole on the side of my tcase so believe me its drained! And do I have to take my shift linkage off? I had to once before for a body lift (to replace one of the metal plate things) and it was a ***** to put it on and off. And one of the rubber gaskets got completely torn off last time
post #4 of 10 Old 01-25-2013, 02:42 PM
biffgnar
biffgnar's Avatar
Just disconnect the linkage down at the TC itself so you don't mess with any of the rest of it.
Romney in 2020!
post #5 of 10 Old 01-25-2013, 02:43 PM
Ironturtle84
http://www.advanceadapters.com/produ...ifter-bracket/
Get one of these. Cheap, easy to install, and takes the bs out of the linkage.
the driveshafts come off with 4 8mm bolts on each end on the front and axel end only for the rear
unclip speedo sensor and range sensor
drop skid
undo 6 14mm nuts that secure the tcase to the tranny
pull off
installation is reverse
Ironturtle84 is offline
post #6 of 10 Old 01-25-2013, 02:48 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Make sure the input gear length is the same between the new and old cases.
Wheelin98TJ is offline
post #7 of 10 Old 01-25-2013, 05:54 PM Thread Starter
RedHotChiliDog
I did that believe me its from a 4.0L auto like my jeep
post #8 of 10 Old 01-25-2013, 07:33 PM
DevilDogDoc
The bolts that hold the TC to the trans are not metric, they are standard. I don't remember exactly what size it was but I believe it was 5/8. The metric worked on the easy to reach nuts but on the hard to get ones it started to strip the nuts out but the standard one worked perfect.
Edit:The FSM says its a .375-24 nut. So 3/8 not 5/8ths
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #9 of 10 Old 01-25-2013, 09:52 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
A 9/16's ratchet wrench and lowering the transmission down as low as possible without BREAKING THE FAN SHROUD are good things to know and have.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #10 of 10 Old 01-25-2013, 09:57 PM
DevilDogDoc
Hey now, my shroud was broken before I swapped out cases...
