#1 | |
Transfer Case Removal / SYE Install
I got my parts in last night for my SYE (Advanced Adapters) installation. Hopefully tomorrow night I'll get a start on it. Anyone have any advice / tips / tricks to keep in mind as I get started?
Also, I've read online that it can be done with the Transfer Case still installed on the Jeep, but the instructions from AA advise that it be removed. Anyone have options of which way? If I choose to remove it, if that a difficult thing? Anything that I need to keep in mind? Thanks
[COLOR=navy][B]97 TJ[/B][/COLOR] - 6" Teraflex Long Arm, 35" x 12.5 ProComp MT - JKS Discos Poweraid Throttle Body Spacer - Airraid Intake Borla Headers - Cat-Back Exhaust - Herculiner Inside [COLOR=darkred]Can[/COLOR]-[COLOR=navy]Am[/COLOR] Jeep Club Other ride: 99 Grand Cherokee |
#2 |
You do not need to remove the t/case. Get yourself a good manual, Chiltons, Haynes or FSM to go along with the instructions. Follow them closely, and it's a couple hour job.
Good luck, Chuck
2007 Rubicon Unlimited, Black on Black, stock for now! 2005 Grand Cherokee Laredo, wifes ride. 2004 Chevy 2500 HD Duramax Deisel, tow rig. 2002 Wide Glide, for those really nice days! 1998 XJ, 4" Superlift, 31X10.5 A/T's on Micki Thompson Classis II rims. Soon to be for sale. Traded - 2003 Rubicon, 4.5" RE Superflex lift, 33" Yokohama M/T's, Black Teflon A/R Chamber rims, front/rear Warn bumpers with swing out carrier, Shrockworks rock sliders, MM 9K winch. |
#3 |
Oh yeah, make sure you have a GOOD set of snap ring pliers!
#4 | |
My JB Conversions super shorty should be here today actually. :-) |
#5 | |
Master of Reality
BTW, I did mine with the TC still in the Jeep. I made an installation video, if anyone wants to see it. You can find it via search, or ask me and I'll post it again. Chuck
Chuck Grissom Black Jeep Society Member My Jeep Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas A. Edison |
#6 | |
#7 |
Do it right or not at all
![]() Join Date: Jan 2003
Though I was ready to remove my t-case to install my SYE kit, friends who came over to help convinced me to leave it in. They (mrblaine was one of them) were right, it was far easier and quicker to just leave it in. And it's not that the snap-ring pliers need to be "good quality", they just need to open far wider than the usual pliers do. Tool trucks like Snap-On and Matco have them, I had zero luck finding them in tool stores.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#8 | |
Master of Reality
Chuck
#9 | |
#10 |
that video is some of the best jeep porn ive ever seen. very nice.
#11 |
SYE Install problems
GET YOURSELF A GOOD MANUAL BEFORE YOU START!!!
Mine was a TerraFlex SYE Kit and the instructions didn't match my 2003 TJ. When I called TerraFlex for help on Friday afternoon they said their instructions were only meant to be a guidline and a good manual was required to do the job. Well, thanks for letting me know first. I completed the install OK but it took much longer that it should have. |
#12 |
Moab dreamin'
The AA instructions are pretty good. There is one large snap ring which the AA instructions tell you to remove which I read after my install did not need to be removed, other than that though they seemed fine. I did mine in-vehicle with no regrets.
#13 |
Much easier to do it in vehicle, that way you don't have to mess with shifter linkages and the nuts on the studs that hold t-case to the tranny can be a pain to access.
Reno4x4.com |
#14 | |
Brake Wizard
Not only that, but some of the stuff that needs some force to remove takes another set of hands when it's on the bench to keep it steady and not moving all over the place. Much easier in the jeep. Drain the fluid before you do anything else. Then get tall jackstands, I have 6 ton versions that I have tack welded to the top of some dually rims. Jack the jeep up as high as you can get it via the pumpkin on the rear axle and set the frame on the tall stands. That will give you enough room to sit up comfortably under there and make it much easier.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#15 |
i broke my oil pump when i did mine so becareful around that . i was a little hesitant about doin one myself but i was fairly easy
87 YJ sbc,th350,33's, rusting away in some junkyard 91 YJ 4" ,33's, most likely rusting away somewhere 97 TJ 4",33's,full skids, driven daily 07 JK Rubi,2.5",35's, wheeled hard, traded in 07 JK Unlimited Rubi,2",35's,RiverRaider skids & cowl snorkel |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
