Transfer case rattle/grind - JeepForum.com
post #1 of 6 Old 10-12-2008, 11:59 AM Thread Starter
KeyserGogo
I bought this TJ back in July. It's had a weird rattle/grind comming from under the driver seat since I bought it. I assumed it was the U-Joints and just pulled both drive shafts recently and all joints operate quietly and have no slack in them. I've been driing for a few days without the front driveshaft because I am convinced that it was the CV joint making all that racket. The noise is directly related to vehicle speed, not engine rpm. It's kind of like a chattering/slapping sound as you accelerate/decelerate/ maintain speed. Its best heard at 30mph and below. It happens in gear and out of gear, clutch in or clutch out.
Today after doing a search for "marbles" I got some pretty interesting info. Decided to try an experiment. With the JEEP PARKED, ENGINE OFF, I put it in 1st gear, and transfer case in 4lo. The front driveshaft is still off. I crawled under there and tried to spin the front output yoke on the transfer case. It's got about an 1/8th of a turn in it. That seems like an awful lot of slack in there. Should there be any play in this thing? Seems like it shouldnt be able to move at all. Any info would be great, I'm tired of hearing this grinding/rattling sound as I pull out of gear and slow down.
Green 1998 Sahara
KeyserGogo is offline
post #2 of 6 Old 10-12-2008, 03:06 PM Thread Starter
KeyserGogo
it seems to me like maybe the chain is stretched? does that make sense? i havent pulled a transfer case apart in 6 years, but i remember last time when I put it all back together you could spin the front output shaft in 2HIGH and it was whisper quiet. in 2HIGH on this jeep I hear a "whirring" sound, like the metal gears and chain making noise. Any input? Should I have this slack on the output shaft when in 4HIGH/LO?(yes it has about an 1/8th inch of play in each direction in 4HIGH and LOW)
Green 1998 Sahara
post #3 of 6 Old 10-13-2008, 01:36 PM Thread Starter
KeyserGogo
anyone...?
Green 1998 Sahara
post #4 of 6 Old 02-07-2010, 10:14 AM
jeepbro's
Bump for an old thread and a similar problem. Sounds similar to the symptoms i have. but mine doesnt do it unless its like 5-10mph and up. Sound just like op described, my only thought when i heard it was sorta like rocks in a jar or scratching glass kind of sound that rocks would make. Any thoughts from anyone??
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #5 of 6 Old 02-24-2010, 10:28 AM
jeepbro's
bump again, does this sound like a transfer case chain problem? i think a sound i'm getting is similar to the OP's
post #6 of 6 Old 12-07-2010, 07:01 PM Thread Starter
KeyserGogo
Old thread... I know... i never returned to post the cause of the noise. Turned out to be pitted bearings in the rear diff. The sound eventually got loud enough to pin point to the rear. Jack stands and a mechanic's stethoscope work wonders haha. Good Luck
Green 1998 Sahara
Why does my transfer case grind gears when shifting into 4hi! skipilot YJ Wrangler Technical Forum 6 03-08-2009 07:43 PM
Transfer case grind silvertjul TJ Wrangler Technical Forum 5 08-22-2006 10:49 AM
Transfer case rattle? ChevDog1 YJ Wrangler Technical Forum 6 03-14-2006 01:28 PM
Transfer Case Rattle spderjhn TJ Wrangler Technical Forum 2 10-28-2005 02:59 PM
Transfer Case rattle.... charliezulu TJ Wrangler Technical Forum 3 03-29-2005 09:43 PM
