#1 | |
Transfer case problems
Hello
I just got my first jeep last week from a dealership and already had a new radiator put in, now my 4wd is messed up. Its hard to explain but the lever is off from what it is supposed to be. you pull up for 4 high but i dont get 4h untill i pull it to the right and up further almost to where neutral is. That is where i get my 4h then i pull it all the way up and it barley touches 4L it stays in for 10feet if im lucky. I was wondering if this happened to anayone else and how they fix it so the dealer doesnt BS me and tell me its something not under warrenty.
#2 |
sounds like it needs a simple adjustment. look under the jeep at where the tc shifter comes tru the floor, there is a rod from the shift lever that goes toward the front. it should have a bolt pointing down at about a 45 degree angle towards the driver side. loosen the bolt so the rod can be moved forward about 3/4 of an inch and then retighten then try it to see if it will shift into 4lo and stay there.
#3 |
do it on a dogsled
these pics are of the linkage and alignment your looking for, the bracket noted was added after a 4"lift
04 Black unlimited, 4"lift, 33" GY Silentarmors, OME shocks, stablizer warn 9500ti winch,optima yellow top, full bottom armor #200 v.2 black jeep club |
#4 |
Thank you, when ever it stops freezing rain here I'll adjust it.
#5 |
I just adjusted mine because I was having the same problem as the OP, I can get into 4hi just fine, but shifting into 4 lo grinds every time and then kicks back out, if I am slowly moving the indicator light comes on and immediately off, if i shift in when I am in N, then put it in gear it grinds and kicks back out. It is getting very frustrating now not having 4 lo, any more ideas on how to get 4 lo back.
#6 |
i decided to take it to the dealer because it was still under warrenty, waste of time they did not do anaything. they said to put it in 4L you needed to turn the truck off and that didnt work so im gonna have to do it myself.
#7 |
The Mac Lover
They told you that??!!
Support bacteria. It's the only culture some people have |
#8 | |
![]() Please tell me this isn't a Jeep stealership! You should be able to shift into 4-hi while moving at any speed. To shift into 4-lo, slow down to a crawl (<5mph) and shift into 4-lo. Just remember, don't use 4wd on dry pavement. Good luck! |
#9 |
it is one of those dealerships that the owner owns three of them. it was at hyundai, and they brought a tech from the dodge dealership next door, so i had two tech's telling me that was the problem.
#10 |
Your owners manual has a pretty good run down on how to shift into 4WD. Suggest you take the manual with you and call them on the BS and tell them to fix it!
#11 |
i just did it myself and now im experiencing 4l thanks for the pics they really helped.
K&N pannel filter, got that far before i ran out of money |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
