Transfer case Problems? - JeepForum.com
post #1 of 14 Old 03-07-2011, 06:04 PM Thread Starter
Porgie
I've had my TJ for about a month now and haven't had any problems until today. The problem is with my transfer case (I Think). I have a 2000 TJ Sahara with the 4.0 and an automatic transmission and 106,584 miles. Everything is stock as far as i can tell.
Here's the problem: It was snowing in NY and i was driving at about 20mph and i shifted from 2H to 4H and my transfer case went to neutral i played around trying to get my jeep out of neutral and found that all of the positions are wrong. I got the Jeep into 2H and found 4H which was about half way to the 4H position and when I pull the handle into the 4H position it shifts to neutral. The other problem is that when the jeep was in transfer case neutral and i final stopped i could not put the auto trans. into park, there was a lot of grinding and i needed to shut the jeep of to put it into 2H. The Jeep drives the same with no noises or bumping or slipping in both 2H and 4H.
I need help trying to figure this out. I don't think the T-case is broke because it drives fine but i'm not sure about the linkage between the handle and the T-case. I've heard that there is a poor design of these parts and i know there are relocation brackets. I've also heard that shifting to 4L can mess up the transfer case if the Jeep is stopped or going to fast, since I've only had the Jeep a month and I don't know what the previous owners have done. Any suggestions or ideas would be greatly appreciated and i plan on fixing the problems my self. Is there a way to check the linkage without dropping the T-case.
Thanks
Porgie is offline
post #2 of 14 Old 03-07-2011, 06:14 PM
RockMonster
is there a body lift? this is probably going to be one of those situations where you need to crawl under the jeep and switch manually to see if its just some kind of shift bracket problem or an internal problem.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #3 of 14 Old 03-07-2011, 07:27 PM Thread Starter
Porgie
There is no body lift that i know of and it looks like the tub is on the frame. How would I shift manually from under the Jeep. This is my first 4x4 and i don't have access to a lift so can i do it with just a floor jack and jack stands.
Porgie is offline
post #4 of 14 Old 03-07-2011, 07:33 PM
srlbotanical
Is this the first time you have put it in 4WD?
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #5 of 14 Old 03-07-2011, 10:15 PM Thread Starter
Porgie
No this is not the first time but when I used 4H before it was just for a few minutes to get traction in an ice covered parking lot ... I didn't notice any problems except that it felt a little stiff.
Porgie is offline
post #6 of 14 Old 03-08-2011, 07:07 AM
srlbotanical
My guess is that you just need to adjust the t-case linkage. Do a search, it's pretty straight forward. It helps to have a friend shift the t-case while you are under the jeep adjusting things.
HIGHER POWERED!!
post #7 of 14 Old 03-08-2011, 07:50 AM Thread Starter
Porgie
Should I replace the linkage, I've searched the internet and a lot of people say that the t-case linkage is a poor design because it attaches to lever to the tub and then to the t-case. Are there any recommendations on new linkage that you might have or is the factory linkage good enough and i should keep that and just adjust it?
Porgie is offline
post #8 of 14 Old 03-08-2011, 07:59 AM
JC_Sahara
Replacing the linkage isnt necisary. If you are stock, then you most likely just need to adjust the linkage. I had to do the same thing after I took apart my np231 for a new output shaft and driveshaft.
My Build Thread:
JC_Sahara is offline
post #9 of 14 Old 03-08-2011, 08:41 AM Thread Starter
Porgie
Thank you for the help I'll probably just adjust the stock linkage and then upgrade it to Novak when I do a suspension lift.
Porgie is offline
post #10 of 14 Old 03-08-2011, 10:21 AM
JC_Sahara
Do it! I went with the Advanced Adpaters shift braket from Quadratec. The novak is the cable shifter right? That will be awesome!
My Build Thread:
post #11 of 14 Old 03-08-2011, 04:21 PM Thread Starter
Porgie
Thanks JCOOTJ I want my jeep to be awesome and even though the Novak is the most expensive option I've seen It's also the best option I've seen. Spending money isn't wasting money if the product is worth the price and my wife keeps telling me just do it right the first time.
Porgie is offline
post #12 of 14 Old 03-08-2011, 05:25 PM
rondak46
Originally Posted by Porgie View Post
Thanks JCOOTJ ..... and my wife keeps telling me just do it right the first time.
Get the Novak cable, and keep your wife!
rondak46 is offline
post #13 of 14 Old 03-08-2011, 09:31 PM
JC_Sahara
Quoted for truth (not married though) lol.
My Build Thread:
post #14 of 14 Old 03-09-2011, 08:15 AM Thread Starter
Porgie
Thanks for the advise. I love the wife and the Jeep.
Porgie is offline
linkage , transfer case
Transfer Case Problems Svyse YJ Wrangler Technical Forum 2 12-17-2010 07:34 AM
Transfer case problems abramsg YJ Wrangler Technical Forum 1 05-05-2007 08:23 AM
transfer case shift linkage problems after t-case drop heezy101 TJ Wrangler Technical Forum 5 08-29-2006 06:02 AM
Transfer Case Problems . . . ? Jurisimprudence TJ Wrangler Technical Forum 0 12-12-2003 03:11 PM
transfer case problems YoungJeeper YJ Wrangler Technical Forum 2 10-26-2003 07:27 PM
