transfer case problem??? - JeepForum.com
post #1 of 2 Old 09-28-2008, 12:09 AM Thread Starter
Emagg
I think i might have a problem with my transfer case. i have a 2000 jeep tj with 4inch rough country lift and when you push the transfer case selector all the way down in 2wd you feel like a grinding. also when i hit a pot hole or a bump in the road you feel the same grind. I noticed that if you just pull up slightly on the selector that the grinding will go away. i think it might need adjusting but how do i know exactly how much to adjust it. please help
Emagg is offline
post #2 of 2 Old 10-29-2008, 11:37 PM Thread Starter
Emagg
i found that the noise i thought was a grind turn out to be a dry gromet the held the transfercase shifter to the body that was giving me the sound and feel of a grind. they lubed it up at the car shop and it seems to be gone. hope this helps any one with the same problem
Emagg is offline
Transfer Case problem mbojaj YJ Wrangler Technical Forum 3 07-28-2009 12:22 AM
Transfer Case Problem? aaron89yj YJ Wrangler Technical Forum 3 09-14-2007 05:09 PM
Transfer Case Problem Gurrenteed555 YJ Wrangler Technical Forum 3 06-06-2007 08:46 AM
transfer case problem 1rockhead YJ Wrangler Technical Forum 2 02-05-2007 10:18 AM
transfer case problem? BumbleBeeTJ TJ Wrangler Technical Forum 6 10-17-2004 05:02 AM
