transfer case problem? - JeepForum.com
post #1 of 7 Old 10-13-2004, 08:29 PM Thread Starter
BumbleBeeTJ
BumbleBeeTJ's Avatar
i changed ALL the fluids 5000miles ago but just yesterday, the transfer seem to have a problem
I shift to 4 HI works ok, but when i go back to 2WD, the lever feels loose.... when i try to put back into 4HI( while going below 55mph) it doesn't feel right. it feels like the gear has been stuck in 4 HI and never disengaged to 2wd then couple minutes after that, CLUNK! and it dis-engages....
i don't think that sounds too good....any thoughts on what may be wrong?
2014 JKUR 6spd --> 2015 JKU AT
BumbleBeeTJ is offline
post #2 of 7 Old 10-13-2004, 09:29 PM
Spiderman
Spiderman's Avatar
Do you have a body lift?? AFter my 1" BL/MML I still had to install the T/C linkage relocation bracket. I then had to adjust the nut that connects the linkage to the shift level to get everything lined up good. Before I adjusted the screw, I had a hard time holding 4lo and then when I went to shift back into 2hi, it kept slipping back into 4hi.
2001 Sport 4.0L, 5 Speed, Patriot Blue
33 X 12.50 BFG A/T's with A/R Atlas 15 X 8 wheels
4.56's, RE 3.5" lift, Currie 1" BL, M.O.R.E. 1" MML
Aussie D30 Locker, & other crap
Spiderman is offline
post #3 of 7 Old 10-13-2004, 09:52 PM Thread Starter
BumbleBeeTJ
naw itts stock.
no problem holding 4lo but feels like the 4hi doesn't DIS-ENGAGE when put into 2wd ...while im driving like 40~50mph
post #4 of 7 Old 10-13-2004, 11:05 PM
Twig
Haven't honestly heard of this before, but you could still check to see if the linkage needs to be adjusted, very possible. Even though it says you can shift it at speeds, I never would recommend doing so; try when going slow, thats just how I treat mine.
Twig is offline
post #5 of 7 Old 10-17-2004, 03:23 AM Thread Starter
BumbleBeeTJ
i just changed my fluid today Mercon dexron III....cleaned it out and fill it in.....
STILL same problem...even at low speeds like 30mph or so
WHAT THE HELL???
4lo works fine ....i just have problem going from 4hi to 2wd
post #6 of 7 Old 10-17-2004, 03:33 AM
kfxracer8
try coming to a complete stop, then doing it. I dont think its good on that t-case to switch at speed, eventhough it says you can
kfxracer8 is offline
post #7 of 7 Old 10-17-2004, 06:02 AM
lgp
I had the same problem when I first got my used 99SE (8000mi). I was using the 4 hi more than I should have (road conditions did not require it). I changed fluid to Mobil I synthetic ATF and it behaves much smoother now. Clunking stopped.
Ron
lgp is offline
4wd/transfer case problem? clemon YJ Wrangler Technical Forum 2 05-25-2009 10:31 AM
transfer case problem??? Emagg TJ Wrangler Technical Forum 1 10-30-2008 12:37 AM
Transfer case problem MAX_Xj YJ Wrangler Technical Forum 2 03-26-2008 10:38 AM
Transfer Case Problem? aaron89yj YJ Wrangler Technical Forum 3 09-14-2007 06:09 PM
Transfer Case Problem bonjo TJ Wrangler Technical Forum 2 12-30-2006 02:53 PM
