Quantcast Transfer Case Plug Removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Transfer Case Plug Removal
Old 11-28-2008, 08:50 PM   #1
davecam
What size allen socket do I need to remove the drainplug on a 2005 tj rubicon? I have found posts online that say 10mm...but that looks way too small. I'm going to the hardware store tomorrow to pick up a kit.
Thanks
davecam is offline   Reply With Quote
Old 11-28-2008, 09:37 PM   #2
alecmcmahon
alecmcmahon's Avatar
it is indeed a 10mm allen socket
here is instruction on what to do.
good luck.
http://jeep.us41.org/transfercase/index.html
-my build thread-
alecmcmahon is offline   Reply With Quote
Old 11-28-2008, 10:34 PM   #3
davecam
good luck.
Doesn't my year have a different transfer case? I should have the NV241 Rock-Trac transfer case right?. i measured up a standard 10mm socket (not allen socket) and the 10mm was way small.
Old 11-29-2008, 07:42 AM   #4
JohnP
Your '05 Rubicon should have an NV241 same as my '06 Rubi. I just crawled under mine to verify that a 10mm Allen socket fits perfectly. The transfer cases are the same, maybe they changed the plugs between '05 and '06?
~John
1998 TJ Sport
2006 TJ Rubicon
2007 KJ Liberty
JohnP is offline   Reply With Quote
Old 11-29-2008, 09:15 AM   #5
alecmcmahon
i couldnt confirm or not, but just do yourself a favor and buy yourself a full set
of sizes to work with. Im sure you'll use em in the future as well.
- Alec.
-my build thread-
Old 11-29-2008, 10:44 AM   #6
davecam
I just found out this mornign by trial and error fill plug uses 14mm and drain plug uses 17mm. Good to go.
Old 11-29-2008, 01:48 PM   #7
JohnP
Those are for the transmission. They are on the right side of the NSG370 6 speed manual. See the first post in the following thread:
http://www.jeepforum.com/forum/f9/nsg370-oil-change-506637/?highlight=NSG370
The transfer case plugs are on the rear end and are 11mm.
~John
1998 TJ Sport
2006 TJ Rubicon
2007 KJ Liberty
Old 11-29-2008, 02:28 PM   #8
jeep06
You are correct on the fill and drain plug allen socket sizes... the transfer case (241) fill and drain plugs take a 10mm allen socket.. I also confirmed this since I just finished checking my t/c fluid minutes ago.
Flame Red 2005 Rubicon Unlimited, 4.0L, 6sp, dual tops, Valvoline VR-1 10w30 engine oil/M0-090 Mopar filter, Amsoil Synchromesh 5W30 trans. oil, IPF 920hc head light conversion with PIAA Xtreme White plus bulbs, PIAA Xtreme White Plus H-3 fogs, Armadillo front/rear bumper caps and Olympic grille guard. Amsoil SevereGear 75W140.
jeep06 is offline   Reply With Quote
Old 11-29-2008, 03:24 PM   #9
JohnP
Oops, I mistyped, should be 10mm for transfer case, 14 & 17mm for the transmission.
~John
1998 TJ Sport
2006 TJ Rubicon
2007 KJ Liberty
Glock Forum
