Quantcast Transfer Case Novak Shifter Intall.. - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Transfer Case Novak Shifter Intall..
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 06-11-2008, 05:17 PM   #1
RVA_TJ06
Had a problem with my install today.
Couldn't get the length of the threaded rod with the two hem joints on either side to fit right. I called Novak and they said people have cut them. Anyone else had this problem. I gave up until I knew that it had been done before.
Finally paid off...
RVA_TJ06 is offline   Reply With Quote
Old 06-11-2008, 05:21 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Did you change any of the mounting locations in the bracket from how it ships from the factory? I had a hell of a time getting my Novak shifter set up properly until I restored it back to the way it was put together by the factory. I didn't realize they kind of pre-set it for a TJ. I don't think I ended up cutting any of the threaded rod off but it's possible since I had help and there was a lot of frustration getting it put together so it shifted properly. It's great now.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 06-11-2008, 05:22 PM   #3
Tim
i didnt cut mine
my install
97 TJ 4.0, AW-4, Clayton, A.R.B., Highly polished HP30, Super 88
There are no shortcuts to any place worth going
91 XJ 4.7
Tim is offline   Reply With Quote
Old 06-11-2008, 05:25 PM   #4
Jerry Bransford
Hey Tim, a big hearty welcome to JF! What, as the resident Novak expert do you have a permanent crawler set up so you can detect Novak shifter discussions no matter what Jeep forum they're in?
Getting Savvy...
Old 06-11-2008, 05:28 PM   #5
Tomb Raider
MyJKRocks!
I knew that name sounded familiar.
Welcome back.
Tomb Raider is offline   Reply With Quote
Old 06-11-2008, 05:30 PM   #6
Tim
hi jerry,
been a member for a while (03) but i tend to lurk here more than post which is very, very obvious huh?
91 XJ 4.7
Old 06-11-2008, 05:45 PM   #7
RVA_TJ06
I originally had it in the set position it was sent in. t. dome, yours looks like a completely different assembly...
Mine looks like this...
http://www.novak-adapt.com/images/pics/linkages/sk2x_v2_assembled_view.jpg
Finally paid off...
Old 06-11-2008, 05:49 PM   #8
Jerry Bransford
T-Dome has an earlier version that has a reversed shift pattern where 4Lo is forward and 2Hi is pulled all the way towards you. You and I have the same newer version of the shifter which has the same shift pattern the OE shifter does.
Getting Savvy...
Old 06-11-2008, 05:55 PM   #9
RVA_TJ06
Hmm. I was trying to line it up with the hole in the tub, as if it was reverse shifting, I read that it was reverse shift pattern.
Any pictures jerry??
Finally paid off...
Old 06-11-2008, 05:59 PM   #10
Jerry Bransford
I don't have any pics like T-Dome has but I'll look tonight when I get home to see if I have one that might be useful. If you bought it recently, it's a non-reversed shift pattern. Some older ads might still say it has a reverse shift pattern but Novak switched it after too many complaints. All currrently shipping Novaks shift so all the way forward is 2Hi, all the way back is 4Lo.
Getting Savvy...
Old 06-11-2008, 06:02 PM   #11
RVA_TJ06
Just got it tuesday.
TIA for any pics.
Finally paid off...
Old 06-11-2008, 06:04 PM   #12
Tim
i think i can make mine shift with 2 lo to the rear and 2 hi up front but i like it the way it is for now. its cooler to have weird jeep stuff these days
btw novak is a great company that offers wonderful customer service. i like their product too
91 XJ 4.7
Glock Forum
