Transfer case leaking out the speedometer gear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Transfer case leaking out the speedometer gear
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!Advance Adapters SYE Kits
Unread 07-16-2014, 02:59 PM   #1
Jeeper69
(Recently swapped the speedometer gear, made sure to put new o-ring on it)...leaking out of it, leaking a lot!
Jeeper69 is offline   Reply With Quote
Unread 07-16-2014, 04:10 PM   #2
2jhanna
Pull and recheck. O-ring could be not seated correctly or split.
jhanna
denton county, tx
2jhanna is offline   Reply With Quote
Unread 07-16-2014, 04:37 PM   #3
ravenworks
Buy a new o-ring for $1
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline   Reply With Quote
Unread 07-16-2014, 04:58 PM   #4
Leffnasty
X2 probably seated incorrectly. Pull it back out and try again
Leffnasty is offline   Reply With Quote
Unread 07-17-2014, 08:15 AM   #5
Pentara
If you didn't do the swap yourself, it's not impossible the mechanic forgot to put on the o-ring, especially if you are really leaking as opposed to a slight drip.
Either way, you need to pull the speedo-gear and check if it's not seated right, missing, or perhaps damaged during the install.
Funny story, the previous owner of my jeep decided to save some $ and put silicon around the speedo-gear instead of using an o-ring. It didn't leak, but what a mess it was to remove when I put in the right size gear.
Pentara is offline   Reply With Quote
