Transfer Case Leak - JeepForum.com
post #1 of 5 Old 03-28-2008, 01:28 PM Thread Starter
mlb2003
Transfer Case Leak
it looks like the t case is 2 pieces (the housing). it looks like its leaking from where the 2 pieces meet. it looks the same way in the rear of the tcase. can you tell me what i need to replace to get it to stop? its not leaking from either of the shafts. it looks like its at the bottom of the tcase.
thanks
35x12.5x15" tires, 2" coil spring lift, 4" X series Rough Country Lift, 7" Rugged Ridge Fender Flares, hanson 60" bumper front with prerunner and fender bars, LOD extreme rear bumper/tire carrier, high lift, Delta 7" headlight replacements, Warn 9.5ti w/synthetic line, hella black magic lights, sye/cv ds, D30/44 with arb lockers, tera disc brakes, 4.88 gears and shafts
mlb2003 is offline
post #2 of 5 Old 03-28-2008, 03:26 PM
Jeepin' Rock Cl
If it's just the seal leaking, it's not too bad. Pull the rear drive shaft out, drain the fluid, unbolt the case half, remove the back half of the case, clean both mating surfaces, RTV the front half, slide the rear half back on, bolt to spec, put the DS back on, fill with fluid.
Jeepin' Rock Cl is offline
post #3 of 5 Old 03-28-2008, 03:58 PM Thread Starter
mlb2003
how do i know if its just the seal? the big piece that the shaft goes into, that bolts to the face of the tcase, has fluid at the bottom of it.
mlb2003 is offline
post #4 of 5 Old 03-28-2008, 10:06 PM
bail315
If it was leaking from the output shaft you would probably be seeing ATF being slung around the underside of your Jeep. Making a new seal for the transfer case is not to difficult with the right tools. It shouldn't take more than a few hours. When you split the two halve just remember to keep the bolts in the same order you remove them in. You will notice that they are different lengths and they need to go back in the correct place.
bail315 is offline
post #5 of 5 Old 04-02-2008, 12:37 PM Thread Starter
mlb2003
thanks. im just going to wait until i put on the sye/cv driveshaft then worry about it.
mlb2003 is offline
Transfer Case Leak Shane64 TJ Wrangler Technical Forum 12 05-28-2008 08:30 PM
Transfer Case Leak smok3y YJ Wrangler Technical Forum 16 03-08-2004 12:30 PM
Transfer Case Leak... Bighaeb YJ Wrangler Technical Forum 2 05-10-2003 10:44 PM
Transfer case leak???? nalis YJ Wrangler Technical Forum 5 03-03-2003 06:48 PM
Transfer Case Leak BamaRulz YJ Wrangler Technical Forum 3 02-23-2003 10:18 AM
