Transfer Case Fluid - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Transfer Case Fluid
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 05-22-2015, 06:39 PM   #1
steven81
Transfer Case Fluid
I am planning on changing the fluid in the transfer case. I have a 2001 TJ sport. I have done some research and a lot of people say to use ATF +4. My manual says to use Dexron III or ATF +3 Type 7176. I am just wondering what all of you use and also just curious if I would do any damage putting in ATF +4?
steven81 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 07:18 PM   #2
Shark_13
ATF+4 is compatible with parts spec'd for +3, you'll be fine using +4.
http://www.allpar.com/mopar/transmissions/fluids.html
Shark_13 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 07:37 PM   #3
MDTJ
As I understand it, all ATF is backwards compatible. So you can always use a higher number than listed.
This is my signature. I was told to type stuff here.
MDTJ is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 08:09 PM   #4
26679cj5
I think atf+3 was semi-synthetic and +4 is full synthetic?
26679cj5 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 12:44 AM   #5
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Unlike an automatic transmission, the transfer case is not fussy about the exact type of ATF it runs on. Any of those choices are fine, ATF+4 would be a great choice.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 09:25 AM   #6
steven81
Thanks for all the help. I think I am just gonna go with the ATF +4 even though its a little more expensive. Not sure it has ever been changed before so I want to change it before I go hit the trails this summer.
Unread 05-23-2015, 01:29 PM   #7
MDTJ
Make sure to pull the fill plug first, before you drain it. If it won't come out, you'll want to know that before you drain the fluid.
Unread Yesterday, 10:55 PM   #8
steven81
Next problem. Fill Plug will not budge. I have hit it with heat, some PB blaster and its not budging. Any ideas. This is what my bolts look like.
Unread Yesterday, 10:59 PM   #9
BYuen
Get a good breaker bar or impact on it. Make sure you use the right sized Allen bit or you will strip the plugs easily.
BYuen is offline   Reply With Quote Quick reply to this message
transfer case
