transfer case exhaust problems - JeepForum.com
post #1 of 5 Old 01-27-2014, 02:37 PM Thread Starter
SGTxDIX
transfer case drop exhaust problems
my jeep tj has a 4in suspension lift and has a transfer case drop that is a at least an inch, maybe more. the first exhaust hanger is a bolt on bracket mounted on the transmission which has been dropped so it has brought my whole exhaust system down with it. since this mount is bolted on i was wondering if anyone makes a new one or if anyone has fabbed up something i could copy. i dont have the money for a sye kit or else i would just do that and be done with it. i just need a solution for this since it is causing multiple clearance problems
SGTxDIX is offline
post #2 of 5 Old 01-27-2014, 08:24 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
My transfer case/transmission skid plate is raised, but maybe you can get the idea?...
Knuckelhead is offline
post #3 of 5 Old 01-28-2014, 12:43 PM Thread Starter
SGTxDIX
Here are some pictures to explain it better.
This is the mount im talking about
These are the problems i have had because of the mount being lowered from the transfer case drop
SGTxDIX is offline
post #4 of 5 Old 01-28-2014, 01:25 PM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
That's the cat mount.I've never had a rubbing issue from a t case drop on any of my nine Jeeps.
TheBoogieman is offline
post #5 of 5 Old 01-28-2014, 06:47 PM
Knuckelhead
AFSOC Retired
Your transfer case drop causes the exhaust "Y" pipe to swing to the left and it then interfaces with the front driveshaft. Installing a MML would help with the exhaust clearance, installing a transfer case lift and relocating the cat hanger would work also... IMO
exhaust , transfer case drop
