Transfer Case drop elimination questions - JeepForum.com
post #1 of 7 Old 05-04-2009, 10:30 PM Thread Starter
ciscok1d
So right now i have a 3" BDS lift kit with a transfer case lowering kit and steering stabalizer. I'm starting to hate the tc being so low, and i plan on installing the JKS 1.25" bl/mml after i put my 33's on. If i do the body lift do you guys think i can ditch the tc drop, add a tummy tuck and be alright? Or do you think i'll need a need a sye eliminator and cv shaft in addition?
I will probably go ahead and try this, just trying to figure out if i need to save more money ahead of time i guess.
Thanks for the advice in advance.
ciscok1d is offline
post #2 of 7 Old 05-04-2009, 10:32 PM
jeep95xj
1995 XJ Cherokee
the BL does nothing to help or hurt your driveline angles. If you do a tummy tuck you will need a SYE and CV shaft
jeep95xj is offline
post #3 of 7 Old 05-04-2009, 10:45 PM
imustbenuts
Every jeep is different. However, the odds are you will need the sye with the tt.
On my first trail run:
imustbenuts is offline
post #4 of 7 Old 05-04-2009, 10:46 PM Thread Starter
ciscok1d
cool, thanks for the quick reply. Now i can get this done in stages...
ciscok1d is offline
post #5 of 7 Old 05-04-2009, 10:47 PM
AlTheKillerr
AlTheKillerr's Avatar
never heard of a SYE Eliminator before
but with the BL/MML you can get rid of the tcase drop however to do a TT im quite sure you will need a SYE/CV
Photographer
AlTheKillerr is offline
post #6 of 7 Old 05-04-2009, 10:54 PM Thread Starter
ciscok1d
I didn't even notice that..
ciscok1d is offline
post #7 of 7 Old 05-04-2009, 11:00 PM
ScottHarr_TJ
2010 WK
I got rid of my drop with the bl/ mml combo and dropped a few washers under there to clear out all the vibes. rides like butta! but every jeep is different and with the TT im pretty sure you'll need the CV/SYE. good luck
00' TJ-sold
'10 WK
Blue Jeep Club Memeber #132?
ScottHarr_TJ is offline
MML/ transfer case drop Questions vosevichs TJ Wrangler Technical Forum 8 02-11-2010 02:16 PM
Transfer Case Drop Question...To drop or not to drop? dswi YJ Wrangler Technical Forum 11 07-24-2009 02:33 PM
Transfer case drop or skid plate drop? JIME TJ Wrangler Technical Forum 2 04-08-2009 06:10 PM
To drop or not to drop transfer case SkyLand TJ Wrangler Technical Forum 22 10-13-2007 01:43 AM
transfer case shift linkage problems after t-case drop heezy101 TJ Wrangler Technical Forum 5 08-29-2006 06:02 AM
