Transfer Case 4WD Sensor - JeepForum.com
post #1 of 5 Old 10-15-2010, 04:12 PM Thread Starter
GrantLasson
What size socket do I need to remove the transfer case 4WD or "position sensor?" Does anyone know?
Mine's in the wrong position--it reads 4WD in 2WD. (It's in position 2 when it should be in position 1.) I've confirmed the problem and I'm trying to go through the floor pan to remove it and then re-seat it deeper.
Thanks for your help.
GrantLasson is offline
post #2 of 5 Old 10-19-2010, 07:46 AM Thread Starter
GrantLasson
1 1/2" deep socket
For the record, the Transfer Case Position Sensor is 1 1/2"
I was able to remove it through the floor pan without much difficulty. Just remove the transfer case shifter (lift really--I never removed it entirely). The sensor is located right there on top of the transfer case.
For me, it was easier to go through the floor pan than to remove the skid plate and long arms that were in the way down below.
BTW, thanks to the Jeep parts dept because they allowed me to measure a new position sensor with a caliper--without buying!
post #3 of 5 Old 10-19-2010, 09:27 AM
Slithering_Joe
Originally Posted by GrantLasson
What size socket do I need to remove the transfer case 4WD or "position sensor?" ...
For the record, the Transfer Case Position Sensor is 1 1/2"...
Are you talking about the switch for the "4WD" indicator? I just did this not too long ago and I'm pretty sure I didn't use a huge 1-1/2" deep socket to remove it. I think I used a 7/8".
Here's a pic by another member:
4.0L TJ
Slithering_Joe is offline
post #4 of 5 Old 10-19-2010, 10:10 AM Thread Starter
GrantLasson
I should clarify: the 1 1/2" is for an NV241 Rock Trac transfer case. Other TC's may have different sized sensors. I know the Rubicon sensor is 1 1/2".
post #5 of 5 Old 10-19-2010, 11:43 AM
UnsanePyro
Yeah, I just had to do mine in a 231 case, and it definitely wasn't that big, probably 7/8 like another member said. I didn't have to pull anything apart either, I did it from under the Jeep, with a box wrench.
UnsanePyro is offline
LOUD violent POP from transfer case on occasion from my lifted Rubicon transfer case anymanusa TJ Wrangler Technical Forum 14 07-23-2010 04:54 PM
Transfer case boot for 231c transfer case in jeep wrangler kniteman YJ Wrangler Technical Forum 2 03-16-2009 01:28 PM
Bent rear diff and cracked transfer case, what diffs and case will bolt into my 87 YJ hillside250 YJ Wrangler Technical Forum 9 01-08-2009 12:45 AM
transfer case issues 91 auto to 88 standard case... input shaft?? dream911tommy YJ Wrangler Technical Forum 1 12-22-2008 11:23 AM
Diff and transfer case fluid transfer hint BillArf TJ Wrangler Technical Forum 11 06-26-2005 07:42 AM
