???? on trans issues - JeepForum.com
post #1 of 3 Old 11-01-2002, 03:03 PM Thread Starter
heep98
heep98's Avatar
Hey Iam new to this board and I have a 98 2.5 peice. The problem I have is trying to get it in gear. The clutch is all the way in and it feels like it is stuck and the gear shifter wont move. Is this clutch or could it be something else, but once it is in gear it has no problems. Also when Iam rolling in first with the clutch in it has a very bad gear whine? Is this normal?
heep98 is offline
post #2 of 3 Old 11-01-2002, 09:16 PM
PreacherTJ
Sounds like the Clutch Plate needs adjusting. IF there is no slippage during shifting --- try tightening the clutch cable, which will mean that it engages/disengages further away from the floor.
Silver 2004 WJ, 2wd, all original (at present)
"Approving the things that are excellent" Philippians 1:10
PreacherTJ is offline
post #3 of 3 Old 11-01-2002, 10:48 PM
mrmagoo1
mrmagoo1's Avatar
how many miles ?
also don't try to adjust clutch cable you have a hydraulic clutch.
Have you changed the tranny oil and checked the drain plug for any metal?
if the the car in front is going too slow
[DRIVE OVER IT!!!!!!
mrmagoo1 is offline
trans to motor mounting issues tonythetiger YJ Wrangler Technical Forum 8 09-27-2009 10:17 AM
Having issues with my 5-speed trans. in my wrangler.. Please help me... Bigtone36 YJ Wrangler Technical Forum 4 01-26-2009 04:22 PM
Automatic trans. shifting issues oleman55 TJ Wrangler Technical Forum 0 09-13-2008 05:46 PM
Creaky 03 Clutch and Trans Issues TheChad03 TJ Wrangler Technical Forum 6 01-31-2008 10:00 PM
Trans swap questions/issues teqmod YJ Wrangler Technical Forum 10 04-09-2005 07:00 PM
