Trans cooler - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Trans cooler
Iron Rock Offroad products - get them from Kolak!WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 02-28-2015, 08:40 AM   #1
Vic99TJ
Trans cooler
Hello fellow jeepers! So I'm looking for a trans cooler for my 03 Rubi. I don't want one with a fan. Just one that goes in front the rad. Any suggestions on size? And do you add it before or after the rad cooler? One last question. Is there any things that I mite need that wouldn't come with the cooler? Thanks
Sent from my 03 Rubi!!!
Vic99TJ is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 09:00 AM   #2
Jeeprogue
you can get basic ones from autozone, bout $40 for a decent size one, youl want to get a little more 3/8 TOC hose, and a couple of double sided barb fittings with hose clamps, more trans fluid(duh) and youl want to add it after the factory cooler.
Jeeprogue is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 09:23 AM   #3
Groove508
May I suggest B&M 70264. It's top to bottom measurements let you slide it through your headlight opening but it is thicker than most and rated at 14,400 BTU I beleive. I just installed one on my 2005 TJ two months ago. It comes with a lot of mounting stuff you may or may not use. There was not enough line as I wanted to mount mine with the inlet and outlet facing up as instructed by most. Mount it to the V bracket, I used insulated pipe brackets but I saw one guy just use self tappers with rubber washers? Don't mess with trying to use their brass fittings either, use 3/8" double barbed brass fittings and GOOD hose clamps splicing into your transmission line. The correct one is a debate but I used the return line (post-radiator). You won't lose that much fluid but with the extra line and the cooler, you will need a good quart to get back to full.
Groove508 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 09:43 AM   #4
biffgnar
biffgnar's Avatar
Another recommendation for B&M 70264.
Before or after the OEM cooler in the radiator is something you have to decide for yourself. One school of thought is simply that cooler is better. That would suggest putting it after. Another way to look at is though is that perhaps there is a proper range for temperature and getting the fluid too cool is not a good thing. That would suggest putting it before and allow the two coolers together to get it into that proper range.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote Quick reply to this message
Unread 02-28-2015, 10:33 AM   #5
JBTJ
The 70264 is a good cooler than many use. As for the area you live in and that you see cold weather for any length of time, I suggest adding in in before your radiator. If you add it after the radiator is may get too cooled in the winter months.
JBTJ is online now   Reply With Quote Quick reply to this message
Unread 02-28-2015, 11:07 AM   #6
Jeeprogue
derale also makes a thermostat for your trans cooler if you wanted to keep it cooler in the summer without freezing it in the winter.
Unread 02-28-2015, 04:36 PM   #7
Vic99TJ
Thanks for the replies. I was looking the Derale 13503. One onther question. I don't have ac so can I mount it straight to the rad with the zip ties?
Unread 02-28-2015, 07:58 PM   #8
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Using zip ties to mount it to the radiator isn't a good idea, mount it to the support "V" rods in front of the radiator using adel clamps.
http://www.google.com/search?q=adel+...2&ved=0CDkQsAQ
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 08:30 PM   #9
Vic99TJ
How do they go around the cooler? This is a rad style cooler not the tube style.
Unread 02-28-2015, 08:35 PM   #10
Knuckelhead
AFSOC Retired
That's a manifold style cooler and the adel clamps mount to the mounting holes in the end plates on the cooler, the adel clamps around the "V" support rods...
Unread 02-28-2015, 09:19 PM   #11
Vic99TJ
Oh ok makes sense now! Thanks
Unread 02-28-2015, 09:32 PM   #12
Knuckelhead
AFSOC Retired
You're welcome, post back as to how your install goes.
One thing to think about is if the cooler is of the appropriate size, you can install it through the drivers side headlight opening without having to mess with the A/C condenser or the radiator...
Unread 04-09-2015, 02:20 PM   #13
Pacsur
Originally Posted by Knuckelhead View Post
That's a manifold style cooler and the adel clamps mount to the mounting holes in end plates on the cooler, the adel clamps around the "V" support rods...
I have to order the adel clips online, could you tell me what size you used?
Pacsur is online now   Reply With Quote Quick reply to this message
Unread 04-09-2015, 07:40 PM   #14
Knuckelhead
AFSOC Retired
I don't remember, you could measure the diameter of the support rod?
Did you check at your local hardware and automotive stores?...
Unread 02-05-2016, 08:38 PM   #15
GreenbayTJ06
How did you install the fitting to the stock cooler?
GreenbayTJ06 is offline   Reply With Quote Quick reply to this message
