tranny/ tc problem - JeepForum.com
post #1 of 2 Old 04-21-2008, 06:31 PM Thread Starter
rubicon35
tranny/ tc problem
my buddy has a 92 or 93 yj 4.0 with manual tranny and something has gone bad from flywheel back to tc. when he was sitting at an intersection it just started banging really bad(it matches with the rpm). when he pushes the clutch in it goes away but as soon as the clutch is engaged it comes back. we pulled the tranny and tc yesterday thinking the flywheel was cracked or had a bolt backed out on it. It looked fine, when we turn the input of the tranny you can hear the knocking it sounds like it coming from the front of the transmission. the input shaft also has alot of play in it. im guessing its just a bad bearing??? its got around 120k on it and he plays really hard. any ideas on what this would be????? i have no experience in opening up a transmission do you think this is something i could tackle or just let a mechanic go at it?
rubicon35 is offline
post #2 of 2 Old 04-21-2008, 10:27 PM Thread Starter
rubicon35
anybody???
Tranny Problem BigJake737 TJ Wrangler Technical Forum 2 03-08-2009 01:18 PM
Tranny Problem diehnjeep YJ Wrangler Technical Forum 3 07-26-2008 02:35 PM
tranny problem 03Wrangler YJ Wrangler Technical Forum 8 01-10-2007 07:12 PM
Tranny problem zach1288 TJ Wrangler Technical Forum 11 08-06-2005 06:28 PM
Tranny problem ToolMan YJ Wrangler Technical Forum 3 12-03-2003 09:25 PM
