Tranny swap 6spd to Auto. Worth it? - JeepForum.com
post #1 of 14 Old 08-07-2013, 12:12 AM Thread Starter
kitsrider
I really would like to swap out my 6spd for an auto. My last TJ had an auto and it was so much nicer to drive. ANy links you guys could give me or advice on the swap would be helpful. Thanks
kitsrider is offline
post #2 of 14 Old 08-07-2013, 12:13 AM
Necko2529
Necko2529's Avatar
What year was your last TJ?
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #3 of 14 Old 08-07-2013, 12:16 AM
wtfcrunch
But why easier to drive yes but Jeeps were meant to be manual in my opinion. What year is your jeep?
-_________________-
Tyler Laros
San Diego, CA
wtfcrunch is offline
post #4 of 14 Old 08-07-2013, 12:18 AM Thread Starter
kitsrider
Last TJ was an 01 Sahara, current is a 05 LJ.
post #5 of 14 Old 08-07-2013, 12:21 AM
Necko2529
Necko2529's Avatar
Your 01 had an 32RH and was a 3 speed. If you're planing on swapping 42RLE in place of your 6 Speed NSG370 you might want to do some reading into it. Unless your LJ has a front axle that can be geared deeper than 4.88 it would be undergeared for your 35" tires. Youre better off keeping your NSG370.
post #6 of 14 Old 08-07-2013, 12:24 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Some people like automatic transmissions, some like manual transmissions.
Who knows, you may change your mind as years go by?...
Knuckelhead is offline
post #7 of 14 Old 08-07-2013, 12:30 AM
thirdeye
definitely dont swap in a 42rle
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #8 of 14 Old 08-07-2013, 12:41 AM
wtfcrunch
the 05-06 NSG370 tranny is made by Mercedes (parts are a nightmare) and the 42LRE has a steep overdrive ratio.
Both have their faults but there are threads out there about swaps being done
-_________________-
Tyler Laros
San Diego, CA
post #9 of 14 Old 08-07-2013, 12:53 AM Thread Starter
kitsrider
I just feel like I am constantly shifting with this thing. I have only owned 4 Autos out of 40+ Vehicles. Maybe In getting old and lazy?
Ok before I make any sudden moves, I need to lose this awful TC drop. Will a SYE kit do it , do I also need a longer Drive shaft. I have a 2" BL and unsure if there is a MML in this thing. I looked and it doesn't seem like it. I would like to do a flat skid but would be happy with the current where it originally was. Looks so pathetic how it is. Thanks.
post #10 of 14 Old 08-07-2013, 06:28 AM
2k2wranglerx
I'd trade you my auto for your 6 speed setup. It's too bad you're so far
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline
post #11 of 14 Old 08-07-2013, 08:28 AM
rchase559
A SYE and a double cardan (commonly incorrectly called a CV) drive shaft should take care of the vibes so you can remove the TC drop. You will however need upper and lower adjustable control arms, an angled rear track bar bracket and probably a couple other things I'm missing. You will likely have to do someting with the lower shock mounts or coil buckets as well since rotating the axle may cause the shocks to hit the coil bucket.
You could do a search and get numerous threads that go into detail on this. Here are a couple to start.
http://www.jeepforum.com/forum/f9/so...y-tuck-942018/
http://www.jeepforum.com/forum/f9/wh...nt-one-854790/
rchase559 is offline
post #12 of 14 Old 08-07-2013, 10:53 AM
biffgnar
biffgnar's Avatar
As somebody with a 42RLE with 137k miles on it and no real issues I do believe the suckiness of it gets a bit exaggerated but if I were doing this I'd really try to find a way to make an AW4 work. Have that in my XJ and the combo with 4.0 seems worlds apart from the 4.0/42RLE combo.
Romney in 2020!
biffgnar is offline
post #13 of 14 Old 08-07-2013, 11:25 AM Thread Starter
kitsrider
Great info guys! Thank you.
post #14 of 14 Old 08-08-2013, 03:17 AM
tytrev
Had trouble with reverse in a 05 TJ with 42RLE at 91k miles...didn't like it.
97 TJ SE: Building for medium trails
62 CJ5 Willys: Restoring to original...well close to original
Who cares about my other cars? They're not JEEPS!
tytrev is offline
